Thread: What do I need
    zephard's Avatar
    May 2013
    Houston, Tx
    100
    What do I need
    I am looking at getting a gunite IG pool with the pebble sheen finish. I would be using a SWC and a cartridge filter. What would I need to clean my pool as far as brushes, cleaners etc? How often would I need to scrub/clean the pool? I know I need to order the testing kit recommend and I have read the pool school but need to read it again. Thanks
    Pool: IG, 8'W x20'L x5' deep, 6000 gallons, Stonescapes Blue Tropics Mini-Pebble gunite pool
    Equipment: Hayward SwimClear 3030 cartridge filter, SP32102EE Tristar 1 HP 2-speed pump,
    Universal H-Series Low NOx H400FDN (400K BTU) heater, SWG = Hayward Aqua
    Rite with Turbo Cell 9, and a Navigator XL cleaner
    Ground break 7/12/2013 Filled 8/6/2013
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: What do I need
    Welcome to TFP
    You've already read pool school so you're on the right track. You really won't need a whole lot of gadgets. In addition to the usual components that are part of the pool build (which you've already mentioned), you really only need a pole, net and brush.
    As far as brushing goes, if you are talking about a new pool, you will be brushing a lot the first week. After that, you should follow what pool school recommends HERE.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    zephard's Avatar
    May 2013
    Houston, Tx
    100
    Re: What do I need
    Thanks for the reply. On the Pebbletech website it does say I need a nylon brush so that with the net, pole and test kit gives me a start. I want to do things right from the start. Thank you.
    Heading over to read the automatic pool cleaner info in pool school.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: What do I need
    One thing I would strongly suggest if the work is not done yet, talk to your pool builder about laying out your pad with future maintenance in mind, all pipes should have union fittings, space should be left for splices, if ball valves are used they should be threaded with slip to thread PVC adapters, etc. Many pool builders seem to plumb pads as compactly as possible leaving no space to repair anything, instead the first time you have to change out a pump or filter, or even just add a heater, you have to rip out all the plumbing, and perhaps even jack hammer up the concrete if they plumbed fittings too close to the ground.
    I would also suggest dedicated lines to all fittings, drains and skimmers, it does not cost that much more now, but can save you a fortune later.
    Ike
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: What do I need
    Quote Originally Posted by Isaac-1
    Ike
    This is something I have pondered many many times looking at new installs here and elsewhere. Why oh why do they build these manifolds to the equipment that there is no possible way to repair without a major cut out and re-do?? I look at these set ups and think of the horror I would have trying to cut in a replacement valve or some such thing. It just boggles my mind to look at some of these.
    Essential Links:
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Re: What do I need
    No kidding! I have a "built in" overflow valve next to my skimmer (center of big concrete deck). I always "thought" it filled when level went down an inch or two, and it drained when level when up an inch or two. I've looked at it several times and does fill when level goes down, but when it rains pool never seemed to go back to skimmer level (I always have to backwash if it gets too full). I'd assumed the drain port was clogged somewhere in the plumbing... finally decided to run a snake down the port and discovered the drain port was capped (about an inch into the concrete). Why would this even be installed if it wasn't going to get plumbed correctly? Seems things like this and the skimmer should be off to a side of the pool with no deck (or at least access to ports), not in the center of concrete where there are no options. Fortunately (or unfortunately lately) it doesn't rain much here and evaporation takes care of lowering the water level 90% of the time.
    Having said that, I have same finish. As long as you have a good TEST KIT and don't let your FC get low, you shouldn't need to brush much at all. I brush maybe 2 or 3 times a year (and that was only when I let FC get to low and algae started growing on plumbing). Have a Legend that "came with" the house and does a good job keeping things clean (just bought a robot that should do even better). Leave some extra room around your equipment in case you decide to "expand" (heater, liquidator...) as Ike suggested. Good luck!
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
