Thread: How much Chlorine can be produced from a SWG
    Jun 2007
    Houston, Texas
    209
    I have a Hayward SWG (not yet installed) and I'm wondering what is the maximum FC output. I know there are many factors like pump capacity, flow rates, chlorine consumption, etc. but I'm looking for and approximation. I haven't seen anything in the literature.
    36,000 gallon IG Gunite (40 x 20), 1.5 HP Hayward pump, Pentair Nautilus NS-48 DE filter, 2 skimmers, 12 - (2 x 20) Fafco Solar Panels (Goldline controller not hooked up yet), Hayward Swimpure Plus SWG, Blue Pearl Robot cleaner. New Dr. Wellness X-12 standalone Lifestyle Spa.
    Which model do you have? Chlorine production by a SWG is typically stated as lbs per day assuming 24 hour run time at 100%. 1 pound per day is about the average.
    Jun 2007
    Houston, Texas
    209
    Swimpure... Thx
    Do you mean the SwimPure Plus? It is able produce up to 1.45 lbs of chlorine a day. That is about 360 oz of 6% bleach, not quite three gallons.
    How that translates into FC levels depends on the size of the pool, bather load, amount of sunlight, CYA level, etc.
    Jun 2007
    Houston, Texas
    209
    Yes, Swimpure Plus... Man you are a wealth of knowledge. I constantly read your input in the forums and your awesome.
    I can't thank you enough for all you do.
