Results 1 to 9 of 9
Thread: Question about the right cya level for my pool?
    Hey guys been reading threw pool school and getting all the information I can to do the BBB style, so far my pool is clear and the fc level is around 6.5 to 8.5 on average. I test everyday with the tf-100 kit, great kit makes it so easy to know what is happening, but anyway I brought my cya level up to 40 by using the solid form of acid in a sock placed close to the skimmer. my question is that my pool is exposed to ten hours of sunlight a day and there no shade in the back yard @ anytime during the day. should I increase my cya level say to 60. I know on the chem geek's chorine/cya chart that a cya level of 70 should have a target level of 8.0 fc.right now I put a 1/2 gallon of bleach @8.25% every evening. when you have a cya level of say 60 is ok to fall a little short on the target fc or should it always stay right@ target level.
    13,500 gallon, 24ft round pool, Hayward 1.5hp matix pump and sand master filter. treating with the BBB method.
    38,371
    Re: Question about the right cya level for my pool?
    A higher CYA will lower the FC loss to the sun, so you should have to add less bleach every day.
    You just need to make sure the FC stays above the minimum level for your CYA in the Pool School chart.
    The danger of higher CYA is that the shock levels for FC are higher if a problem developed.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You want to stay in the target range a don't let fall below the min. Try raising your cya to 50 and see how your FC levels do. With all that sun exposure you want more cya.
    Jeff
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by ridgerunner
    It still has to stay above the minimum, and the minimum increases with higher CYA. At 60 or 70 you're getting beyond the zone where you can just have a look at the color block - you'll need the FAS-DPD test every single time. Try 50 and see what happens. You can always add more, but removing it is a PITA.
    does adding a 1/2 gallon of bleach a day sound like to much for my size pool. I don't mind adding the bleach .
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I have the same size. I use a quart and a half on sunny days. With that much sun that's a normal amount. That's why I said to increase cya to 50
    Jeff
    thanks guys I shoot for a 50 cya level and go from there. I sure don't want to mess things up. everybody that comes to house brags about how good the pool looks. I Love this method. thanks guys
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Sounds good. Just remember to raise in 10 ppm. Don't want to get too high. Like Richard said PITA to lower.
    Jeff
    Jun 2011
    Long Beach, CA
    2,790
    The Pool Calculator is saying you are adding about 3 ppm of chlorine a day if the bleach is 8.25%. This is a little on the high side, not bad though. A little higher CYA and you will most likely lose only 2 ppm a day which is a good amount for a pool in the sun.
