Results 1 to 9 of 9
Thread: Why Do Bearings Go?
    Why Do Bearings Go?
    Hey folks,
    I just replaced the Motor on my Hayward 1 HP Super Pump almost exactly 2 years ago. It's been great. Nice and quiet. Yesterday I noticed some water leaking from the bottom of the pump though. Today there's a semi-loud whining noise coming from it, that from what I can tell sounds like the bearings are shot.
    With it only being a 2 year old motor, I've gotta ask...why would the bearings be shot already? What would cause it? Doesn't seem to be a simple fix like a seal or gasket would be, so I'll probably end up buying a new motor (closest motor shop, which isn't very close, is almost as expensive as a new motor for repair). I want to avoid this happening in another 2 years though, so what could have caused it so I don't do it again?
    Thanks!
    18 X 36 In-Ground Vinyl Pool, Hayward 1 HP SuperPump, Hayward SP270T 350lb Sand Filter, CompuPool CPSC48 Salt Chlorine Generator, Hayward H400FDN 400 BTU Natural Gas Heater, 2 returns, 1 skimmer, No Main Drain
    38,371
    Re: Why Do Bearings Go?
    The pump seal leaks which gets the bearings wet and then they fail. As soon as you see any sign of water leaking, you should replace the seal.
    Ahh, thanks. But in that case, why would the seals fail so soon then? Thanks again
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Cause they sure don't make stuff like they used to mostly.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Actually, a better question would be "Why do bearings last so long?" Consider the speed they're spinning without much cooling or lubrication. Hours and hours, sometimes for days at a time. They're pretty amazing.
    I think seals are made cheaper, for less drag or something, trying to get the most efficiency.
    Well, I guess that's better than that I screwed something up...kind of. Ok, one more question. Can anyone tell me the difference between the following 2 motors? Last time I bought the UST1102, and these seem to both be that, but they've got different prices with different descriptions, but both sold by Amazon. But since they're both the UST1102, are they both the same motor? Does one include something the other doesn't? Thanks
    http://www.amazon.com/A-O-Smith-UST1102 ... ds=UST1102
    vs
    http://www.amazon.com/Electric-UST1102- ... ds=UST1102
    38,371
    Look the same to me. No interest in an upgrade to an energy efficient motor or even better a 2-speed to save money on electricity?
    I'd love to, but last I looked into it, I'd be looking at some serious $$$. If you have some suggestions of how it wouldn't be too expensive, I'm definitely interested
    Sorry, forgot one other thing...Do new replacement motors tend to come with new seals and gaskets or should I plan to order those as well?
    Thanks a ton everyone!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    About 300 for the 2-speed pump and somewhere around 30 for the seal kit.
