Thread: Milky Blue Water
    Milky Blue Water
    I got the Taylor test kit and discovered that my CYA was off the charts so I drained about 2/3 of the water from the pool and refilled last week.
    My current test results are:
    FC 0
    PH 7.4
    Alkalinity 100ppm
    Hardness 190ppm
    CYA 40
    It's a 13,000 gallon pebble tec pool with a DE filter that I cleaned and re-charged two weekends ago.
    I know I need to raise the FC. I've got a chlorinator with 3" pucks and will add a gallon of bleach per the Taylor analysis instructions. I also put a sock full of CYA in the skimmer to stabilize the chlorine.
    My question is about the color of the water. It's a milky blue; I can see to the bottom in the deep end but it's not clear. What should I be doing to clear it up?
    Rick
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Milky Blue Water
    Welcome to tfp, rickmacc
    Quote Originally Posted by rickmacc
    What is your CC?
    How much did you put in...you are already at 40 ppm and we recommend 30-50 ppm for cya. See: http://www.troublefreepool.com/pool-...mmended_levels Also, granular cya can take a week to show up in test. cya can only be removed by partial drain/refills. Also, I would remove the pucks out of the chlorinator since they are adding cya as well. See: http://www.troublefreepool.com/pool-..._chlorine_pool For now I would use liquid chlorine/bleach.
    Likely you need to do the shocking process. In that pool school article it mentions the OCLT, I would do that tonight.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Yeah, what he said ^^^^
    Those pucks are probably what got you into trouble with high CYA in the first place.
    And Welcome!
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    IMHO, you don't need to add stabilizer at this time. Take the sock out and let it dry for later.
    I just did this process with my pool with weekend. I would keep your FC up using only liquid chlorine and let the pool sit overnight (pump off) and then vacuum to waste whatever is on the floor.
    Mine was milky blue in the evening and looked milky blue in the morning (could NOT see liner design on floor). After I vacuumed to waste, it was less milky and more blue (but not clear). I could see the liner pattern on the floor. Then kept filtering, vacuuming to filter, and bumping my Perflex. It is much better now. I still have some floaties but the surface load is killing my with all my crepe myrtle mess (see my Pool Skim thread)
    -- Guy --
    OK, thanks everyone. I'll remove the CYA sock from the skimmer. I just added 1 gallon of chlorine bleach. I'll check the FC in the morning and go from there.
    Rick
