Thread: Can't seem to get my pH up and my TA down....Help
    Hello all,
    This is my second season using the BBB method. I really thought I had it down and everything worked great last year. I opened the pool about 3 weeks ago and have been fighting low pH and high TA ever since.
    Inground with liner - 15,299 gallon
    Current readings:
    pH - 6.8
    TA - 180
    FC - 5
    My chlorine has been holding perfect and the water is crystal clear. According to the Pool Calc they stated to add 304 oz of Borax. I did this a couple days ago and I am still getting the same reading. I have an auto cover so no rain is getting into the pool. It is supposed to be sunny tomorrow so I am going to open the cover and point the returns up to aerate.
    Any other suggestions? I know adding borax should raise the pH and not raise TA, but will that lower my TA?
    Thanks for the help!
    Eric
    15'x4' Metal Frame Intex (3yrs old) 16" 2650gph intex sand filter, TF-100 testkit
    30,419
    Re: Can't seem to get my pH up and my TA down....Help
    The best way to solve your problem is aeration. build a cheap fountain, toss the kids in the pool, etc. Get some frothing and churning going on. It may take a day or two but your pH will come up and your TA will go down.
    Thanks for the suggestion. Sun just came out and I will hook up the fountain and turn my returns up toward the surface.
    Butterfly's Avatar
    South Carolina
    10,045
    Here's a link to the acid/aeration article in Pool School for lowering TA:
    pool-school/lowering%20total%20alkalinity
    Welcome to the forum
    You're done SLAMing when:
    Quote Originally Posted by Butterfly
    Thanks Butterfly! I actually turned my returns straight up to break the surface and that has been running for about 5 hours. I just tested and my pH has already risen to 7.2 from 6.8. Also, my TA has dropped to 120. Going to check in a few hours again to see where it's at and then go from there. I think if I get the pH up a little more I should be good to go. FC is staying right where it needs to be.
