Thread: Prepping and painting an older pool
    Ok so we recently bought a previously foreclosed home with an in ground pool.
    It's a 20'x40' concrete floor with fiberglass walled pool. All in all it appears to be in pretty good shape and had been winterized before being abandoned 2years ago. The question is where should I start? The paint is chipping a little bit and it's my opinion it could use a new coat. We have are hands full with many projects at this house and would like to get the pool up and running to give the kids somewhere to play while we complete other upgrades to the house. Does anyone have suggestions for quickly and inexpensively preparing this pool for use?
    Thanks in advance.
    Ben
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Prepping and painting an older pool
    Welcome to tfp, Jellyman
    I do not have experience with that pool design, but hopefully someone on here who does will respond soon.
    It would probably help to post some pictures, assuming something can be seen.
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    We have a member that has rehabbed a pool similar to yours, with pics
    my-pool-refurb-paint-is-complete-t7086.html
    You're done SLAMing when:
    Thank you. Ill read through the thread.
