Thread: Intermatic Transformer for Volt Lights
    Jan 2011
    Northern Illinois
    116
    I recently purchased an Intermatic transformer (ML200RT) for a low voltage landscaping system I am planning. I am planning on using Volt and Paradise fixtures and using LED bulbs bought on ebay. However, I contacted Intermatic to make sure the transformer was magnetic and has an AC output (which it does). The rep I talked to says it does but that many manufacturers require a Class 2 type of transformer rating for LED lights and the Intermatic transformer is not. The rep said class 2 means it meet the UL, National Electrical Code & ANSI/NFPA 70 approval. I'm not sure what all this means, how important it is, and if this rules out the transformer I bought for LED lights. Thanks in advance for any help!
    Wil-Bar 27'x54" Quest AGP
    Hayward 1HP Powerflo Pump
    Hayward 256 T Swimpro Sand Filter
    Re: Intermatic Transformer for Volt Lights
    If you are using the transformer for underwater lights a class 2 rating is essential, required by code and a very sensible safety precaution. If you are using it for landscape lighting then it doesn't make much difference.
    Class 2 transformers are specifically designed to make it impossible for the transformer to ever short high voltage to the low voltage side, which could be deadly in a swimming pool. A regular transformer can short in that way, and even though the odds of that happening are extremely low, the resulting danger is so high that it really isn't a good idea to go with any but class 2 for underwater lights.
    Jan 2011
    Northern Illinois
    116
    Thanks Jason. The transformer is strictly for landscaping lights (all will be kept at least 10' from the pool). The rep at Intermatic seemed to indicate that a class 2 transformer was required for LED (and not halogen) which didn't make any sense to me.
    Ksnewman's Avatar
    May 2012
    Middle Tennessee
    173
    I have also used Volt lighting and the rep at Volt said that I could use any magnetic transformer. I didn't see the need to use theirs with only 2 of their LED lights as the 300 watt transformer was a bit overkill.. I went ahead and used a pool rated even though lights were more than 10 ft away from pool. Lights are working great. I have them tied into my Easy Touch and have been using them for a couple of weeks.
    18x36 kidney 20,000 gallons IG vinyl. Pentair Easy Touch 8 w/IntelliChlor IC40. Triton II TR100. Pentair Intellifllo Variable Speed. Waterfall/Jump Rock. 2 Pentair Intellibrite lights. TF-100 Test Kit. And a very happy husband who gets to play in the pool without having to take care of it.
    Jun 2007
    New Jersey
    653
    I'm using an ML200RT with eBay LED bulbs in Malibu fixtures. This the third year. None are within 10 feet of the pool. No problems so far.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
