Thread: pump motor quit
    pump motor quit
    can i replace my pump motor with a whirlpool tub pump motor?the motors look the same.can i take the intake(skimmer basket)section off the old one and put it on the new one?trying to save $. 200 bucks for a new one.got an old tub w/jet pump that works good just dont want it anymore. Anyone do this before?
    16x32x7'6", ~23000 gallons, IG, Sand Filter, Vinyl liner
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: pump motor quit
    Welcome to tfp, suseejr
    Assuming you mean the pump/motor and not just motor...maybe...post the make model of both pumps.
    You say your current pump is not working, does it not start, blow a fuse, make a noise, etc.?
    Re: pump motor quit
    well the breaker tripped a couple times,and then while i was backwashing it, i smelled something burning then the pump quit.was not the breaker that time.this was a pump that my buddy gave me last year when the pump i had for 20yrs burned out. he takes down unwanted pools for people and keeps whats good.I knew it was a temp. fix.Im leaning towards just buying a new one instead of messing around with what i have.dont want to do a bunch of work and the have to buy one anyway.i'll get back with the specs
