Thread: Do I need check valve or Hartford Loop?
    May 2013
    North East Ohio
    959
    So I have a heat pump and a stenner injector down stream for bleach....HP says if I have a in line feeder (I.E Pucks) I need one to prevent chlorine backflow to HP, but do I have the same issue with the injector system ?
    Thanks in advance !
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Do I need check valve or Hartford Loop?
    Is your injection system wired so that it is off when the pump is off? If so there should be no chlorine density spike when the pump is turned off.
    May 2013
    North East Ohio
    959
    It is - and/or should be...meaning I will ONLY INJECT while the PUMP is running...so I assume if all works as is then NO check valve....if my timer jacks up I MIGHT inject while the pump is off.
