Results 1 to 7 of 7
Thread: solid CYA?
    solid CYA?
    HI there,
    I've seen quite a few mentioned to solid CYA; but where do you actually find it? and is it less costing than the powder CYA that walmart and other stores sell?
    We got our pool looking great, want to stay on top of it!
    Thanks
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: solid CYA?
    Solid is the powder/granular stuff, as opposed to liquid. The Walmart CYA is fine.
    Re: solid CYA?
    Quote Originally Posted by Richard320
    Thanks Richard, I figured it was; just was hoping to find a lower cost alternative.
    Interesting, just reread this... so putting it in a sock rather than just distributing directly? Does that make it last a little longer?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: solid CYA?
    The problem with granular CYA is that it is acidic and takes a LONG time to disolve (days). If you distribute it directly in the pool you are putting little acidic flakes directly on the pool finish which can damage/bleach it.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: solid CYA?
    Putting it in a sock in front of the return keeps it off the pool surface and speeds up the dissolving. Giving the sock a squeeze once in a while helps speed things along as well.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Re: solid CYA?
    Quote Originally Posted by msgtdan
    Great advise, really digging this site!
    Thank you everyone!
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: solid CYA?
    Once it's all gone from the sock it may not fully register on a test for a week. But adjust chems as if it did. Liquid will usually show on a test right away.
    Dan D
