Thread: HELP !!!! Pool is awful
    We are going to open our pool after a mission trip in the middle of July. It is an above ground pool and the cover blew off so lots of strange things are in there. The water is green and clumpy and tadpoles are in it. I have a sand filter which I will hook up and then I will fill the pool to the top. What do you do next or will I have to empty it and scrub the sides and start all over?
    Thank
    TJ
    Butterfly's Avatar
    South Carolina
    10,045
    Re: HELP !!!! Pool is awful
    Welcome to the forum
    What is pool size/gallons?
    What is your water source..... municipal or well water?
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Welcome!
    We need some facts. If it's not too big of a pool, draining and scrubbing might be the fastest, easiest way. The bad part is that you can't empty a vinyl-liner pool 100% without risking damage to the liner.
    Drain or treat - either way you'll need your own test kit. You can order that now; very few pool stores will stock what you want and will sell you an inferior, incomplete kit.
    Start reading Pool School - link is on top of every page.
    Some inspiration:
    a-little-encouragement-for-those-with-algae-and-new-to-bbb-t57137.html
    frog-filled-green-swamp-to-oasis-work-in-progress-t48213-20.html be sure to look at page 2
    before-and-after-t36785.html
    a-final-picture-set-of-how-well-the-bbb-method-works-t33199.html
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    - read pool school
    - get a proper drop based test kit
    Maintaining a pool is not hard but you need to develop the knowledge required as well as possess the proper tools (ie: test kit, and not test strips) to do it.
