Thread: Opeining Pool - Green Swamp - How many bottles of bleach?
    I'm fairly new to the forum and this is my first post so hope it makes sense. Opened pool two days ago and it was a green swamp. Added some shock (I know, but the CYA was 0) and yesterday added 8 bottle 96 oz bottles of bleach 6% chlorine. Water is now light green and you can see some of the bottom in the shallow end. We did vac the pool bottom & sides.
    How many bottles of bleach do I need to add to knock the rest of the algae out? Pool specs below:
    35,000 gal
    Inground vinyl
    Any and all suggestions will be greatly appreciated. I love this website and have learned so much!
    Shaz
    25,000 gal
    SWG
    Inground vinyl
    Hayward sand pump
    Re: Opeining Pool - Green Swamp - How many bottles of bleach
    Assuming your cya is in the middle of the range (40), your suggested shock level is 15ppm (according to the pool calculator). to get to shock level you would need 11 bottles. if you had a green swamp, as you say, then most (if not all) the chlorine you added was already depleated when you woke up the next morning. my suggestion is to read the "turn your green swamp into a sparkling oasis" article on this site and get a good test kit recommended by this site.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    There's no way to tell how much it will take in advance. A lot depends on how gooey the water is, how much stuff you scoop and vacuum out beforehand, and how diligent you are about replenishing the bleach to keep it at shock level. Here's one success story:
    [center:f9h51tfy][/center:f9h51tfy]
    Thanks so much! The 11 bottles is a starting place. We have brushed the sides and vac'd the bottom, how thorough it was is difficult to tell as we couldn't see anything. I started to read the article you mentioned and was interrupted will go back and finish. I'll keep you posted.
    Shaz
    25,000 gal
    SWG
    Inground vinyl
    Hayward sand pump
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Shaz
    We cannot help you calculate the # of bottles/gallons of bleach/liquid chlorine without knowing what your CYA level is. So, the very first thing we need to know is a full set of test results. Also tell us how you got them, pool store, test kit (which one), etc. This is what we need:
    FC
    CC
    pH
    TA
    CH
    CYA
    Welcome to the forum
    You're done SLAMing when:
