Thread: dirt stains will not come off
    Jun 2013
    bolton, Ontario, Canada
    2
    I have a inground fiberglass pool, and i have dirt stains on the bottom of the pool I suspect that it is dirt scale from calcium. i drained my pool and i cant scrub it off any suggestions would be greatly appreciated
    .[attachment=0:1qaqbya2]pool bottom.jpg[/attachment:1qaqbya2]
    would filling the pool and dropping the ph to 6.0 -7 help??
    pool size ??, 1993 install
    hayward sand filter, jacuzzi 1.0 pump, ionizer
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: dirt stains will not come off
    Welcome to tfp, silverwolf101
    Are the stains rough to the touch?
    If not then:
    What does a vitamin C tablet and a little water do to a test spot?
    What does a trichlor puck and little water do to a test spot?
    Jun 2013
    2
    No its not rough really smooth ran a bunch of tests ill post pics below. stopped before i got to muriatic. oh and thank you this place has already yielded some helpfull advice.
    .[attachment=1:1qfm32zh]before.jpg[/attachment:1qfm32zh][attachment=0:1qfm32zh]after.jpg[/attachment:1qfm32zh]
    30,424
    Your tests indicate the stains are organic. Elevate the chlorine in your pool to twice normal and then keep it there, perhaps for several days, and that should get most of it.
