Thread: I use borax and need to adjust ph up
    Mar 2012
    Eastern Long Island,New York
    82
    My borate level is about 40 already and my ph is 6.8 after massive rain storms.
    Pool calculator says to add 201 ounces of borax to correct. Will this mess up borax level to high or should I use something else to raise ph?
    ph 6.8
    FC 2
    CC 0
    CYA 60
    TA 75
    CH 190
    Vinyl pool. Shocking in progress...
    Thanks
    Rich
    20 X 40 Vinyl IG 28K gallons, Heat Siphon Z700HP, Hayward 4820 DE, Hayward SP3400VSP, Jandy aquapure 1400, TFTest Kit, Pool School, Pool Calculator
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: I use borax and need to adjust ph up
    Quote Originally Posted by lungs414
    Use borax...it will only raise your borate level by 6.1 ppm. 50 ppm target for borates is a guideline. Being a bit above that wont hurt or help anything.
    Mar 2012
    82
    thank you
