Thread: Pentair ScreenLogic Question
    Otis Campbell's Avatar
    Mar 2013
    Lewisville, TX
    78
    About to get our build underway (new-pool-construction-lewisville-tx-dallas-area-t61141.html if you are interested). I have a question about ScreenLogic. Can I access the system remotely via my laptop? I'm finding lots of information about the Apple devices, which is great, but I don't have an iPhone.
    So what I want to get out of this is the ability to see what's going on with the pool while I'm at the office and correct it if possible. My wife is a very smart person but technology is not one of her strengths. So if there's an issue (I've never owned a pool so I don't know what that might be but I'm just anticipating) I want to be able handle it from the office without the "What does that screen say? OK do you see an option for 'blank'?" We have those conversations enough about A/V equipment and neither one of us enjoy them.
    Thanks
    Inground Gunite, plaster surface. 28,000 gallons, modified L shape with diving area and play area, attached spa. All Pentair equipment including SWG, EasyTouch automation, variable speed pump, DE Filter, Nature 2 Express. Taylor 2006 test kit.
    Why should you become a Lifetime Supporter of TFP? Because the first time you have a problem and you get the solution at TFP you will recoup your cost many times over.
    Jun 2013
    Dunwoody, GA
    74
    Re: Pentair ScreenLogic Question
    I recently had a Pentain system installed, I was looking up info on this over the weekend, you will need to get an interface adapter, and load some software, if you want to run over wireless you will need another adapter, looks like about $500 for all, then there is some software I think you need to download, not sure you want to do that on work computer, not sure if they have a hosted solution. let me know what else you find
    http://www.pentairpool.com/pool-owner/p ... ms-418.htm
    also, perhaps you could get a simple Apple iTouch to run it, from the app i dl this weekend, it looks like you can connect remotely or locally.
    PDF sheet, Apple device (APP) or via Windows or Mac machine
    disclaimer- None of this should be construed as IT advice, I only sell software and hardware, I rely on my sales engineer for techy stuff
    Tallman Monterey (fiberglass), 16'x33', 11500 gallons, 480 sq/ft, Depth: 3' - 5' 6", Salt Water, TF-100, Pentair pump, sand filter, Easy Touch Control System, SWG
    Mar 2013
    San Jose, CA
    25
    Hi Otis,
    The short answer is yes. If you go to Pentair's web site, you can download the app for your laptop. It's configured to talk to a demo pool so you can see what it looks like and what it can do.
    To make it work for real, you'll need an EasyTouch or Intellitouch controller and the iPhone/iPadTouchInterfaceKit (P/N520500). You don't need the wireless kit unless it's inconvenient to run 4 wires from your controller to the interface which you'll want inside. If you already have a control panel in the house you can piggy back on to that. You plug the interface into your existing internet connection and you're all set. For remote access you'll have a name like Pentair: 00-xx-xx (xx is based on your serial #) and a password.
    Steve
    14x28 Hydra Pools vinyl pool. EasyTouch, my own web interface (Screenlogic died), Intelliflow VF, 3 Pentair GloBrites, Pentair Master Temp heater, Hayward DE filter. 89" fiberglass spillover spa
    38,392
    You may be interested in this as an alternative:
    android-iphone-control-of-intellitouch-and-easytouch-t52220.html
