I am reaching out to you guru folks, providing every little bit of info (real or otherwise) I have scraped together.
During the warranty discovery phase, it was stated in BOLD writing by vinyl liner supplier AND manufacturer, that even having ppm of 6 or more for a 24 hr period, can fade the liner? This is scary...is this because they've now changed to vastly inferior fade resistant inks vs. old lead inks? That's what I was told by my installer: he was told by the vinyl liner supplier that the inks in current liners are NOWHERE as fade resistant as 10-15 yrs ago.
So all the specific low FC tolerance verbiage from the liner suppliers about ppm and solar blanket is making me gun shy about using the solar blanket, unless proven otherwise.
I took a piece of my old liner and the replacemenet liner and put them in super saturated HTH super hypochlorite shock treatment water solution for several weaks...yes, both liners showed discoloration, but they did not fade ANYWHERE near what my actual original pool liner faded? Again, another tidbit..
I guess I have 2 objectives:
1. I am trying to rule OUT the solar blanket as core cause of fading...I realize tremendous benefits using it: reduced evaporation of water, retains heat, heats up pool in the sun; just a marvelous addition to the pool energy/water management. It is an in-ground reel unit, so very easy to use daily. So when the manufacturer advises not using it all the time, I should take heed? Replacing the liner is a huge and costly undertaking.
2. Actually determining why the liner faded so as not to repeat.
3. Recommendations for test kit using drops please?
