Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 99
Thread: Starting Over-New Water
    Kentucky
    56
    Last year, I had all kinds of problems with my pool water. From this forum, I figured it the problem was caused by a high concentration of CYA. When I opened the pool this spring, I drained approximately 3/4 of the water and refilled the pool from my well. I initially shocked the pool with 1# of Shock that morning. I then took a sample to a pool store and everything tested normal. The next morning, I shocked the pool again with 4 gallons of 8.75% bleach. I am using 3 99% trichloro-s-Triazinetrione tablets in a floater. Can someone refresh me on TFP scheduled maintenance? My pool is 16 x32 w/deepend (+/-10,000 gallons), a 1 hp pump, and 200# sand filter, which I just had the sand changed two months ago.
    16' x 32' vinyl with 8' deep end, appx. 21K gals, 1 hp Water Ace pump, Hayward Vari Flow 75gpm sand filter, 3 returns, 2 skimmers, 2 main drains, Dirt Devil robotic cleaner.
    Casey's Avatar
    SW PA
    10,450
    Re: Starting Over-New Water
    Refreshers can be found in Pool School. All you have to do is read it.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Welcome back.
    Same advice as last year: Get a test kit!
    What you want is already written out in
    [center:1o7i7rqk][/center:1o7i7rqk]
    Kentucky
    56
    I bought the test kit last year and also donated 30 bucks for the forum. I have tested the water myself and the only problem was that it was a little low on CYA. I added 3# stablizer. I have read through the pool school and can not find any recommendation as to when to add bleach. The guy who built this pool told me 6 gallons of bleach once a week (that was 20 years ago). I plan on adding 5 gallons of 8.25% bleach weekly since the bleach 20 yrs. ago was mainly 6%. That is question 1: How much bleach a week is recommended.
    Question 2: What kind of tablets do I need to add to a floater and how often to maintain the chlorine?
    I appreciate any suggestions and apologize for my ignorance.
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome back, Larry
    Post a full set of test results from your test kit. This is what we need:
    FC
    CC
    pH
    TA
    CH
    CYA
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by Larry65
    I bought the test kit last year and also donated 30 bucks for the forum. I have tested the water myself and the only problem was that it was a little low on CYA. I added 3# stablizer. I have read through the pool school and can not find any recommendation as to when to add bleach. The guy who built this pool told me 6 gallons of bleach once a week (that was 20 years ago). I plan on adding 5 gallons of 8.25% bleach weekly since the bleach 20 yrs. ago was mainly 6%. That is question 1: How much bleach a week is recommended. Think Daily, not weekly. And how much depends upon what the test reads. In a few weeks, you'll pretty much know your pool's appetite.
    Question 2: What kind of tablets do I need to add to a floater and how often to maintain the chlorine? Avoid tablets until you can juggle 4 parameters simultaneously and you have room for the extra stabilizer. Figure on adding liquid bleach daily instead. It's really not that much work - check out my signature below
    Kentucky
    56
    FC 1.5
    CC 3
    pH 7.3
    TA 150
    CH 200
    CYA 40
    These readings were this morning. I shocked the pool 3 days ago.
    Richard320's Avatar
    Jan 2010
    19,037
    FC 1.5
    CC 3
    pH 7.3
    TA 150
    CH 200
    CYA 40
    That CC is waaaaay too high. You need to continue the shock process. It's a process that may takes days, not just a one-time super-chlorination. Shock level FC for 40 CYA is 15. So you need to get it to 15 and then recheck it and replenish the chlorine every couple hours until your pool passes the three tests to show it's cleared. It's all in Pool School
    Butterfly's Avatar
    South Carolina
    10,045
    Here's a link to "The Shock Process" in Pool School:
    pool-school/shocking_your_pool
    Kentucky
    56
    I assume I add more gallons of 8.25% bleach to the pool. How often can I do this? Every couple of hours, every 12 hours, once daily? Can you suggest a plan. Once I get the CC to the desired level, how often should I superchlorinate it w/5 gals. 8.25%.
    Also, should I be using the tri-chlorine tabs at all?
    Sorry for all the questions, but I had a difficult time w/this pool last year, so I drained it this year and replaced the water.
    Finally (for now), using the pool calculator, I assume I enter my readings in the left (NOW) column and the TARGET column I do nothing with?
    Richard320's Avatar
    Jan 2010
    19,037
    Every couple hours.
    Once you pass the three tests to indicate the shock process is through, you just maintain the minimum FC for your CYA. You may never need the shock process again if you stay on top of things.
    Until you get the hang of using the pool calculator and balancing the water, I would suggest you not use trichlor pucks. They affect 4 parameters at once, which is probably too many for you to juggle right now.
    So...calculate how much bleach to get to 15 and pour it in. Read pool-school/ for a while, then restest the FC and raise it back up to 15 again. Go read pool-school/ some more. Repeat until the water is clear. By then, you should have picked up some knowledge and you will know the next step.
    We preach knowledge and understanding here, not "dump this in and see what happens" like the pool store.
    Kentucky
    56
    I appreciate the info. THANKS
    Kentucky
    56
    6/12 8aM CDT TEST RESULTS
    Kentucky
    56
    Sorry about that
    Test Results 8AM CST
    FC 4.5
    CC 6.5
    pH 7.2
    TA 150
    CH 200
    CYA 32
    Cl 5
    I added 2 gallons 8.25% bleach yesterday; I assume I continue to add bleach. I must have misread the CYA yesterday because from what I've read at Pool School, CYA doesn't evaporate. Should I add more stabilizer?
    Richard320's Avatar
    Jan 2010
    19,037
    Sorry about that
    FC 4.5
    CC 6.5
    pH 7.2
    TA 150
    CH 200
    CYA 32
    Cl 5
    Just worry about FC and CC right now. Keep adding bleach until the water clears up and the CC gets to .5 or less, then worry about the overnight test and balancing the rest.
    Kentucky
    56
    The water is clear. I'm just trying to learn preventative maintenance for the pool.
    Thanks
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    There's a lot of factors that can cause the CYA reading to change a little (tolerance, lighting), I'd leave CYA alone for now and continue the shock process using 40. It's better to put a little extra chlorine in then not enough, especially with the cc's you have now.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Kentucky
    56
    I really appreciate the patience and advice. Thanks
    Kentucky
    56
    6/13 9AM Readings (Added 4 gals 8.25 bleach @ 3 hr intervals since last test--backwash&rinse filter afterwards)
    FC 5.0 from 4.5 yesterday
    CC 5.0 from 6.5 (down 1.5 ppm)
    pH 7.2 same
    TA 150 same
    CH 220 from 200 yesterday
    CYA 40 same as day before yesterday
    I'm going to continue to add bleach.....This makes 14 gals since I opened pool & replaced 75% of water with well water.
  20. Back To Top    #20
    SkyKid's Avatar
    Apr 2013
    Upstate South Carolina
    137
    Are you sure you're doing the FC test right
    I had a green pool and didn't have CC even close to that high
    14600gal, In-Ground Fiberglass, Haywood s244t Sand Filter, Jandy Apure35 SWG,
    Haywood 2 speed 1hp pump, Haywood Pool Shark, TF-100 Test Kit http://tftestkits.net/
    Pool School http://www.troublefreepool.com/categ...etting_started
    Never been Pool Stored Thanks to TFP
