Thread: Water collecting in seam at top of Intex liner
    vthokie67's Avatar
    Apr 2013
    Brandy Station, VA
    11
    I found a couple posts where folks have dealt with the water that collects in the "V" at the top of the Intex Ultraframe liner, but none offer a semi-permanent low maintenance solution. My pool has only been up for a couple weeks, but I can already feel the trapped water becoming "slimy" and see it becoming a breading ground for mosquitoes and algae.
    I thought of drilling small (1/8" or smaller) holes, one at each leg opening, at the base of the "V" draining outward. "Theoretically" this would allow only a small amount of water to be trapped in this area and new water would constantly flush the old out. I don't dare do this before consulting with the experts, so thanks for any advice.
    algae-in-top-seams-of-intex-frame-pool-t33344.html?hilit=water%20collects%20intex%20liner
    intex-metal-frame-ultra-cleanup-issue-t59396.html?hilit=water%20collects%20intex%20liner
    ~Ken (Intex means "project" in Chinese :wink: )
    <Intex Ultraframe 22' x 52" 10.5K gal AGP, Intex 16" Sand Filter/SWCG/Pump Combo (copper ionizer removed), Hayward SP1091LX Skimmer, hard plumbed, Intex LED light, custom aerator, Hayward AquaBug cleaner, TF-100, planning future solar heater>
    vthokie67's Avatar
    Apr 2013
    Brandy Station, VA
    11
    Re: Water collecting in seam at top of Intex liner
    Having received no feedback and figuring I couldn't do too much harm, I went ahead and drilled 11, one at every other leg opening, 7/64" holes through the outside flap at the base of the "V". Next day, the "V" was bone dry - no more slimy trapped water
    Only problem I encountered was that the drill bit does not cut cleanly and the hole wants to "close up". The ideal tool would be one that punched a clean hole, like a belt punch. I can see my small irregular holes getting clogged with debris over time so I will be looking to punch them more cleanly. Not nearly as scary as cutting the skimmer hole
    Jun 2013
    China Spring, Tx
    6
    i would think a hole punch, like used on leather would work well for this...
    16' Intex ultra frame, Intex sand pump 2650 gph, installed 6-5-2013, SWG, Hayward skimmer
    vthokie67's Avatar
    Apr 2013
    Brandy Station, VA
    11
    Holes cleaned with the brides 1/8" craft punch.
    kyser's Avatar
    Jun 2013
    Orange City, FL
    47
    Thanks for the tip!
    A hot nail would work,too. Grab a nail slightly smaller than the size hole you would want; a finishing nail or brad. Hold it with a pair of pliers, and heat it up with a torch. Hold the flap so you don't pierce both sides, and just touch it to the spot where you want your drain. Keep some water on hand to cool the nail quickly(shouldn't have to go too far ) and exercise caution!
    I've used this method to "weld" two liter bottles together for minnow traps, and it works like a charm.
    6.7K Pro Series 18x48, VL40T32 pump/filter, Hayward skimmer, TF100, and BBB!
