Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: CLOUDY
    CLOUDY
    Hello everyone,
    First just want to say hi and thank you in advance.
    Just open the pool last week. Started the shock process now on day 8 and the pool is still cloudy.
    here are my stats from this morning:
    PH - 7.2
    FC - 29.5
    CC - 1
    TA -110
    CH - 240
    CYA - 65
    I've been out everyday scrubbing, back washing every other day.
    Still some debris on the bottom and doing my best to vacuum it out but its hard to see as its cloudy. I think i am on the right track but last year by day 6 the water was clear.
    Please help.
    Thank you
    16 x 32 IG
    sand filter
    1HP PUMP
    TF-100 kit
    Butterfly's Avatar
    South Carolina
    10,045
    Re: CLOUDY
    Welcome to the forum and congrats on your test kit
    You are on the right track.
    What was CYA level when you opened?
    You're done SLAMing when:
    Jun 2011
    Long Beach, CA
    2,781
    Re: CLOUDY
    Read this thread, my-sand-is-channeled-how-to-fix-it-t7626.html.
    If you have time to watch the filter, you can add some DE to it, pool-school/add_de_to_a_sand_filter.
    Re: CLOUDY
    Butterfly -
    it was around 90 if I remember correctly
    16 x 32 IG
    sand filter
    1HP PUMP
    TF-100 kit
    Re: CLOUDY
    Ping -
    Thank you and i will give that a shot.
    - Read this thread, my-sand-is-channeled-how-to-fix-it-t7626.html.
    If you have time to watch the filter, you can add some DE to it, pool-school/add_de_to_a_sand_filter. I read this and to be clear DE is safe to mix into the pool?
    16 x 32 IG
    sand filter
    1HP PUMP
    TF-100 kit
    Butterfly's Avatar
    South Carolina
    10,045
    Re: CLOUDY
    Quote Originally Posted by joeg
    Butterfly -
    okay, just wanted to verify.
    Re: CLOUDY
    Quote Originally Posted by ping
    I used the de added to my sand filter and in 2 short days my water from from cloudy to clear. What an awesome feeling to see that. I too had to backwashed daily to get the pool cleaned out and thanks to BBB and Pool school and help from my friends here I have a clear and clean pool. Now if the rain would stop I might be able to get in the pool without turning blue from the cold weather we are having. Go figure during the opening and cleaning 2 week process it was so hot I almost jumped in anyway, but waited. Now cold and rainy until Wed and the low temps. Getting my thermals out to go swimming on Thursday.
    ProSeries Above Ground 20x4 Sand filter 1 hp
    Re: CLOUDY
    Quote Originally Posted by connie
    Thank you once again and do you know where i can pick some of this DE up?
    16 x 32 IG
    sand filter
    1HP PUMP
    TF-100 kit
    Re: CLOUDY
    Found some online..
    16 x 32 IG
    sand filter
    1HP PUMP
    TF-100 kit
    Re: CLOUDY
    Sorry does any one know where i can get Diatomaceous Earth in oakville/ Burlington area Ontario Canada??
    16 x 32 IG
    sand filter
    1HP PUMP
    TF-100 kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: CLOUDY
    Any pool store will have it. But it comes in jumbo sized boxes, a lifetime supply. Ask your neighbors. If someone has a DE filter, they'll have a bag. Ask for a coffeecan full.
    Also check the big box and chain hardware stores that have a pool section. It might be called something like "Filter Aid". There's also the cellulose substitutes like fiberclear and seofiber. They'll work, too.
    Pick up the phone and make a few calls.
    Re: CLOUDY
    I grab some filter cleaner from our local pool store.
    thanks again everyone and I let you know how it goes.
    16 x 32 IG
    sand filter
    1HP PUMP
    TF-100 kit
    Richard320's Avatar
    Jan 2010
    18,985
    Re: CLOUDY
    Careful! They might sell you some overpriced stuff to clean DE filter grids.
    Ask for Diatomaceous Earth. Odds are it will be a pretty good-sized bag or box. If it's in a small plastic canister, that's not what you want.
    Re: CLOUDY
    thanks. I found a store that sells DE in 10lb bags $12.99.
    16 x 32 IG
    sand filter
    1HP PUMP
    TF-100 kit
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: CLOUDY
    If I read it correctly, you have leaf debris on your pool floor and your CYA is 90. It sounds like this a great opportunity to get out your pool vacuum (and long pole) and vacuum straight to waste.
    You will get rid of the debris (saving time and money on CL) and you will lower your CYA levels (after re-filling) which will lower your CL shock level and save you money).
    This is assuming your fill water is clean and cost effective.
    -- Guy --
    Re: CLOUDY
    So I grab some DE last night and followed the instructions. Pressure went from 16psi to 17 and I kept an eye on it until I went to bed. Woke up this morning and gauge is reading 30 psi.
    I am still learning but not quite sure how DE works or what to do next. I panicked and backed washed .... Pressure now sitting at 18 when i left for work.
    from what I understand when the pressure goes up there is a blockage somewhere and I assume its from using DE?
    any thoughts.
    Please and thank you
    16 x 32 IG
    sand filter
    1HP PUMP
    TF-100 kit
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: CLOUDY
    I think you did ok with the DE, 1 lb rise in pressure. The spike to 30 was probably because the DE trapped some of the cloudy material in the water.
    Did you add another bit of DE after you backwashed? When you backwashed, you purged the DE and crud it filtered out from your sand. If you pool is still cloudy, you would need to replace the DE so it can gram more gunk.
    Re: CLOUDY
    Quote Originally Posted by Charlie_R
    No I didn't but I certainly will when I get home. So just keep doing what I'm doing until the water is clear. Backwash and add DE.
    thank you very much
    16 x 32 IG
    sand filter
    1HP PUMP
    TF-100 kit
    Butterfly's Avatar
    South Carolina
    10,045
    Re: CLOUDY
    You should monitor the PSI when adding DE and trying to clear the pool.
    From Pool School article - adding DE to a sand filter:
    The very first time you do this, you should keep an eye on the filter pressure for the next 24 hours or so. The improved filtering may quickly catch a lot of very fine particles and send the filter pressure up rapidly.
    Also, you should backwash when the psi increases 20 to 25% above the clean psi reading.
  20. Back To Top    #20
    Re: CLOUDY
    Quote Originally Posted by Butterfly
    I remembering reading keep and eye on the filter pressure but totally forgot about the second parts.
    thank you
    16 x 32 IG
    sand filter
    1HP PUMP
    TF-100 kit
