Thread: Chemistry close???? Cloudy water
    May 2013
    Longview Tx
    21
    My water is "clear" in the sense that i can see the bottom and see people in the water. The water still looks cloudy tho. esp if I am in the water with goggles.
    Numbers are....
    FC-3.5
    Cc-.5
    TA-150
    Ch-400
    Cya-49
    Ph-7.6
    Any thoughts????
    31' round, 21k gal, AG, sand filter, chlorine
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Chemistry close???? Cloudy water
    Chlorine is too low for that CYA level. FC should never dip below 4, and I prefer to have an extra ppm for insurance. Try a big dose of chlorine tonight - take it up to 10ish and give it some time and some brushing
    to mix well.
    Butterfly's Avatar
    South Carolina
    10,045
    ^^^ yep, as Richard said, FC is too low. For CYA of 50, FC is 4 to 8 and never below 4. You can run another OCLT to make sure nothing organic is trying to take hold.
    You're done SLAMing when:
