Thread: Bubbles coming out of both return lines - not loosing water.
    I have bubbles coming out of both return lines and I am not loosing water. My clear pump trap lid seems to be bubble free. When I shut the pump/filter off, My water level goes down to low in my pump trap to even try to backwash. I have an older pump. I can't find any spots that are leaking water while it is running. Help! I have noticed water squirting out of my pump trap drain plug when I turn the system off for a few seconds.
    Just4guinness
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Bubbles coming out of both return lines - not loosing wa
    That drain plug is most likely the problem. It's allowing air into the pump while it is running. I'd bet a new O-ring will solve your problem.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    [center:93pfrrsi]Round up the usual suspects: low water level, stuck weir in the skimmer, loose drain plugs on the
    pump, poor seal on the pump strainer basket, and leaks at the fittings, especially any couplings.
    [youtube:93pfrrsi]vtSmfws0_To[/youtube:93pfrrsi][/center:93pfrrsi]
    I had the same problem and it turned out to be the O rings on both valves on the intake side. Fixed those and problem went away.
    Sounds like you have a different problem, but you know what to look for next.
    Tony
    20' x 40' Plaster with 9' deep end, appx. 32K gals, Pentair Intelliflo VS pump, Hayward SwimPure t-15, 1 skimmer, Polaris 93 Robot, Pentair Mastertemp 400K BTU, iAquaLink wireless controller.
    As it turns out, I had a small crack underneath the drain plug in my trap next to the pump. Epoxy glue fixed it and saved me hundreds of dollars!!
    Quote Originally Posted by tpjenkins
    Tony
