Thread: Accidentally used "chlorine only" vial for TA test!
    Apr 2012
    Yakima, WA
    58
    One time only. Do I need to get a new vial for chlorine testing now? If o, where's a good place to get one?
    Dave
    Yakima, WA (the Palm Springs of Washington!)
    IG kidney 14k gal, 33 x 18
    vinyl liner
    200 lb Sand filter
    3/4 HP pump
    First time pool owner
    Re: Accidentally used "chlorine only" vial for TA test!
    That isn't really a problem. The only reason the vials are kept separate is that the FAS-DPD chlorine test tends to cause a slow accumulation of a black haze on the vial which eventually makes reading the other tests more difficult. As long as you didn't have any problems reading the test results, everything is just fine.
    Mar 2010
    Spring, TX
    1,082
    I agree with this. It takes a while for the hazing to start.
    But if you ever need a new one I would get it from here
    http://tftestkits.net/Kit-Hardware-c7/
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
