Thread: maintnence help!
    maintnence help!
    Hi Im a new owner of a intex 14x48 pool, we put some shock in it cause we Arent to sure what else to do but the water is still turning cloudy and the walls are slimey, we have never done this before so we are clueless ! Is it fixable or do we need to drain it ? What Chemicals do we need to buy to get the pool up and running smoothly ?
    Thanks
    May 2013
    Virginia
    75
    Re: maintnence help!
    Welcome! Start off by reading pool school (button in the top right corner).
    There are two things you need to do to your water - balance and sanitize it. It took me several readings for it to sink in. Then, start reading through the threads here, chances are, your questions have already been asked.
    10,000 gallon inground, gunite, 500lb sand filter. Brand new to this pool thing.
    Casey's Avatar
    SW PA
    10,424
    Pool Mum is right. Check out Pool School and start reading. That's the first place you need to start. And while you're there, order a reliable test kit. Your questions have been asked a million times. The answers are in Pool School. Take special note to ABC's of Pool Water Chemistry. You will find other helpful info, if only you read it.
    Welcome to TFP.
