Thread: Question regarding the pool filter pressure guage readung
    Feb 2011
    La Quinta, CA
    21
    The pressure guage on top of my pool filter is currently reading 32 psi...usually it is around 20 psi. Does this mean the filters inside need to be cleaned or replaced or could it be something else? The water flow coming out of my spa into the pool is way down too. I have cleaned the filter basket and skimmers but not the main filter below the pressure guage.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Question regarding the pool filter pressure guage readun
    A signature with your equipment would be helpful: pool-school/read_before_you_post
    The filter probably needs to be cleaned.
    Mark
