Results 1 to 11 of 11
Thread: Changing how I backwash
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Hi. I would like to change how I backwash my pool. The current setup that my equipment has it running the pipe under ground and it floods a portion of river rock on the side of my house. The water then runs out the side of my yard towards the street. The problem with this is that it floods my neighbor's front yard mostly.
    I would like to change it to where I add a hose to the pipe and then I can direct where I discharge the water (either directly on the street or into the drain). Here's a pic of my setup.
    Can I just cut the pipe and add a hose w/ a fastener to it? Is it just that simple?
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    Re: Changing how I backwash
    Should be. I did the same thing, mine outlet straight into my yard and I repiped it directly to a drain.
    I'd leave the sight glass, as that is a nice option to let you know there is no water leaking past your valve in normal recirculating operation.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,975
    Yep. They sell backwash hoses at Lowes.
    Word to the wise: unroll it get any kinks out before you open the valve. They inflate so fast you won't have time to shut it off before it pops.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Thanks. I didn't see it anywhere in pool school, but what is the recommendation for backwashing speed?
    38,262
    A somewhat high speed, likely around 2500+rpm or so should work.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    The collapsible backwash hose probably won't fit directly over your existing pipe but you'll be able to find an adapter at any home improvement center that's slip/weld on one end (meant to solvent weld to your pipe) and has a barb style on the other end, meant to accept your backwash hose. You'll probably also need a hose clamp to keep the hose on the barb. Since your sight glass and elbow are right next to each other, you'll probably have to cut the pipe a little ways after it heads down from the elbow.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    I bought, what I thought was a decent hose on Amazon (http://www.amazon.com/gp/product/B007OT ... UTF8&psc=1), and after only about 4 uses it's ripped in the middle. I thought I was pretty careful about pulling the hose out and keeping it straight. Could backwashing on high RPM's cause it?
    The Sears Hardware store by me carries this hose. I have even hit it with a weed whacker and still has no leaks. I picked up about 30 feet of it, and it is the best thing I could find next to an actual fire hose, which I also have but haven't needed. The fire house in my area was replacing some of their older hoses and had 50 foot sections of hose that I now have.
    http://www.sears.com/samar-water-dis...&blockType=G14
    22,300 gallon Inground Vinyl Liner pool
    Hayward DE 3620 filter Hayward Ecostar Variable Speed Pump
    1 Skimmer, 2 Main Drains, 2 Returns, 2 step Jets, 8 ft x 3ft waterfall
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    They always pop. Or spring leaks. I probably go through 3 per season.
    If you dont have them rolled out perfectly, any kinks risk an 'explosion'.
    You can stretch it out perfectly and run some hose water through it to expand it a bit when new, and then it will still pop
    The sears one looks interesting, but I dont trust it enough to pay that kind of money. I just buy them super cheap whenever they break. Usually after the first few weeks of summer when the pool is sparkling clean, I am not really backwashing anyway.
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    Yea that wasn't the price I paid. The sears store had it by the foot, not sure what the actual price was, but I'll repost if I'm there again soon.
    forya's Avatar
    Jun 2013
    SE Pa (Bucks County)
    49
    I just bought 50' of that 4" black corrugated pipe at lowes and just roll it up afterwards and hide it behind my shed
    25,000 Gal, Plaster, IG, Auto CL, Waterfall, IntelFlo VS Pump, Dolphin DX6 Robot, TF 100 test kit, Merlin Safety Cover Lots of Trees!, South Eastern Pa
