Results 1 to 7 of 7
Thread: Doing my shock process
    Hi again,
    My last thread had too much going on in it and i'm doing the shock process now so I'm starting a fresh thread.
    Here were my results 6/6
    TC - 0 I honestly couldnt even see ANY yellow
    CC - --- I didnt do any other chlorine tests since TC was 0, or was that wrong of me?
    pH - 6.8
    TA - 45-50
    CH - ~80
    CYA - 0
    Salt - ~700ppm
    6/7 at night I added stabilizer & borax, then later added 3/4 gallon 10% Chlorine.
    6/8 Morning my results were
    pH - 7.2
    FC - 4.5
    CC - 1
    TC - 5.5
    CYA - (Should be 30ppm)
    After this I added a gallon of 10% chlorine and was gone all day for Racing.
    6/9 Today the pool is the clearest it has been yet (thanks again TFP!!)
    My results were the same
    pH - 7.2
    FC - 4.5
    CC - 1
    TC - 5.5
    It seems that I need to add more Chlorine to the pool and get it up to shock levels according to the chart? I have the SWG off and unplugged
    Aaron
    26' Octagon, IG Pool, ~16gal, 5-5 1/2' deep, Liner, Sand Filter, Polaris Autoclear salt system, 3/4hp Pump, Pool Blaster Max Vacuum, TF-100 Test Kit.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Doing my shock process
    Nice work and yep, bump the FC up to about 12 and hold it there (as best you can) until you pass the three tests that determine the end of the shock process. See red lines in my sig.
    You're done SLAMing when:
    Is it alright to vacuum my pool during this process? I usually vacuum on the waste setting so ill be losing and filling a little water. Now that everything is clearer I can see more dirt on the bottom. I brushed it all up yesterday but a lot of it settled at the bottom again.
    My current results are
    FC - 7
    CC - .5
    TC 7.5
    I need to go grab some more bleach and get it up to 12 again.
    Aaron
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    If you have junk on the bottom of the pool (any color junk... black, green,white) it will benefit you to vacuum to waste, assuming you have cost effective, clean water for re-fill.
    I would vacuum before you bleach/chlorinate.
    -- Guy --
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by techguy
    ^^yep, me too.
    Thanks.
    I vacuumed and then had to refill some water. (was below/bottom of skimmer, now back to middle)
    Then last night I checked the water and my FC and CYA were low, CYA was ~10! I raised both, FC to ~12 and CYA to 30-40
    I didnt have a chance to check the water this morning so I threw half a jug of 10% chlorine in there (was going to be 100 today). I was only home from work for a second before running out in a hurry so I threw another 1/4 in there.
    Tonight I just checked the water and here are the results
    pH - 7.0 (looked in between 7.2 & 6.8, it was previously 7.2 before I vacuumed)
    FC - 14.5-15 (little higher than I thought it would be)
    CC - Less than .5!
    CH - 80
    TA - 70
    I'm thinking my shock process is almost complete, I'm going to look at the pool school and figure out how to do the overnight test. I really want to get the rest of the levels up so I can maybe get in it for the first time this weekend
    This looks like just dirt, but this is what I was vacuuming, this is the night after vacuuming before I swept the bottom:
    Aaron
    38,524
    What levels do you want to get up?
    The only thing questionable is the low pH. I think you still have a bit more shock process to go as you have not been very consistent with maintaining the shock level, but hopefully you are close.
