Results 1 to 11 of 11
Thread: Screened porch for 45x12 pool?
    May 2013
    Fort Lauderdale, FL
    423
    After nixing the idea of a $5000 pool fence around our pool for the kids- we're now thinking about having a screened "porch" build around/over our pool. Our backyard has lots of trees that are nearly hanging over the pool. The pool is 45'x12' with a kickout for the steps and sitting bench at the deep end. I'm thinking about an actual roof with shingles that will handle a snow load, and have lots of skylights, then screened panels all around. Then have a kickout to tie into the house's sliding door and have room for our patio table.
    Here are some pics- We would take down the exisiting screened porch, pull the bushes, and have the screens run down where the white rocks are- then a kickout/room ties into house and a wide section to cover the steps.
    Thoughts?
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Jun 2013
    Dunwoody, GA
    74
    Re: Screened porch for 45x12 pool?
    Doesnt seem too complex, I dont know about tieing in roof lines or whatnot.
    Are you trying to keep kids out or tree/yard debris?
    Tallman Monterey (fiberglass), 16'x33', 11500 gallons, 480 sq/ft, Depth: 3' - 5' 6", Salt Water, TF-100, Pentair pump, sand filter, Easy Touch Control System, SWG
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Similar things are done in the deep south, mainly Florida, routinely without the roof. You'll have two problems. First, you'll need to heat the pool because it won't have the sun doing it. Second, you'll probably have to build the structure bigger than you think because the backfill around the pool won't be suitable for a foundation for the structure.
    May 2013
    Fort Lauderdale, FL
    423
    Trying to keep kids, dog, and tree debris out.
    Yes, pool is heated, that's a natural gas furnace on it
    I didn't think about the backfill/foundation issue.
    We're initially thinking about sissor rafters to keep the space open, shingled roof and skylights. Then the sides will be frame posts with screen. If it's too dark, could always use some heavy duty lights.
    Sep 2012
    Orlando, FL
    27
    Like JohnT mentioned... you'll need footers around the perimeter to support the screen cage.
    ~12,000g IG pool w/ Spa and sun shelf, Jandy rs8 automation, Jandy CL340 filter, 2 Jandy Stealth pumps, Aquapure SWG, Ultrapure Ozone and Aquacal heat pump...
    May 2013
    Fort Lauderdale, FL
    423
    We're also thinking about those snow-rated screen enclosures- they have clear windowed roofs, but with screened sliding doors. Maybe a hybrid of the clear roof, but just screens on the sides to keep the budget down. We don't have $50k for a pool enclosure. Maybe $20k......
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Have you considered one of the telescoping pool enclosures like Aqua Shield? http://www.aquashield.com/
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Have you completely nixed the auto cover on tracks idea? It should fall below your budget.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jul 2013
    Baltimore, MD
    28
    Subject: Screened porch for 45x12 pool?
    Quote Originally Posted by zimm
    Hi zimm, we are thinking about doing this exact thing. We are in Maryland (Baltimore City)and don't have a pool yet, but have mosquitoes, critters, leaves, etc. i was also thinking about a louvre system for the ceiling, or glass with shade cloth somehow.
    It would be nice to have something like a 3 season room - screens in the summer, glass in the fall, late spring. But that wouldn't break the bank!
    Did you end up building something screened?
    Elsa
    1600 gal Arctic Wolverine Swim Spa, approx 8' x 14' with Niagara swim current
    May 2013
    Fort Lauderdale, FL
    423
    Not yet. Still learning to use the pool. Might just live with it and redo our current screened porch.
    Jul 2013
    Baltimore, MD
    28
    Ah, we were going to do a screened/3 season porch and then started to think about a pool. It just seemed to make sense to combine the 2 - less permits that way, maybe Well, have fun with the pool!
