Thread: do i have a leak?
    do i have a leak?
    I just installed the my 12x28 aloha II fiberglass pool. Pentair 320 cartridge filter, 1 hp Pentair dual speed motor. I am losing at least a 1/2 of water per day from my pool. I live in Arizona and its been around 115 degrees out here. is this normal evaporation? I am going to do the bucket test on it. however I am looking for some insight as well.
    26,000 gallon IG pool, colored plaster
    60 sq. ft. DE filter with 2 HP pump
    Installed August 2011
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: do i have a leak?
    Normal evaporation is going to be less than an inch of water per day even in most dry hot climates
    Quote Originally Posted by Isaac-1
    thank you for the quick response post. I wanted to also point out we the wind out here has been 23 mph to 32 mph too
    30,416
    1/2 inch is probably normal given your conditions. Let the bucket test prove or disprove that to you.
