I'm using a Taylor K-2006
This morning's readings:
Ph 7.5
TA 130
FC 3.6
CC 2.0
CYA 80
CH 90
Water is clear. No algae at this point. FC seems tough to keep up lately - I have feeder wide open.
Thanks for all of the replies!
Ph 7.5
TA 130
FC 3.6
CC 2.0
CYA 80
CH 90
Short answer: yes, you need to perform the shock process. That CC is too high. For that matter, so is your CYA level and you're making it worse if you're using a puck feeder!
You will be seeing algae soon if you don't get on it fast! Nip it in the bud!
[center:2d24jr28][youtube:2d24jr28]uijLXS-IJZM[/youtube:2d24jr28][/center:2d24jr28]
woitkowski said:
How do I get the CYA down? Change out water? If so, how much?
Liquid Shock or Granular?
The only way to lower CYA realistically is by draining and refilling. Tap water has no CYA, so the math is pretty easy.
Liquid shock or plain Chlorox bleach (or store brand equivalent - check the strength %) is what you need.
Study pool-school/shocking_your_pool
[center:2erkznp7]
file.php
[/center:2erkznp7]
I read "How to Chlorinate Your Pool". Is this a good plan?
I'm going to drain some water (to the return), and refill.
Use liquid shock (have to figure out how much).
Will test everything again afterwards.
Going forward I will turn down the puck feeder and use a maintenance regimen of liquid chlorine (need to figure out how much).
If CYA doesn't go down enough, I'll repeat the drain and refill thing again.
Does that sound like the right thing to do?
