Thread: Venting Stenner pump tank without significant evaporation
    Oct 2010
    Houston, TX
    152
    Ok, so I've got this Stenner pump which is pumping bleach into a spa. The tank has a lip on the top (see picture) surface underneath the pump which accumulates water when it rains, so I sealed the drainage hole from the pump into the tank with caulk.
    But when I did that, the tank could not vent any air and tank would bulge until it leaked bleach everywhere out through the cap onto the top surface. To fix that problem, I drilled a small hole in the side of the tank, but I think there might be a lot of bleach evaporating through that hole (it gets easily in to the mid-90's now here in Texas...)
    So my question is how can I properly vent the tank without losing much bleach through evaporation? Thanks.
    15k gunite pool. Intelliflo VF. Autopilot SWG.
    2k separate spa with waterfall (ie: pain in the rear maintaining a separate body of water). 2HP Hayward Tristar pump.
    Re: Venting Stenner pump tank without significant evaporatio
    Assuming you made a small hole, evaporation is not an issue. It will evaporate to some extent, but so little that it really doesn't make any difference.
    Oct 2010
    Houston, TX
    152
    Wow, you replied faster than I was able to figure out how to embed the image correctly into my post. So, would you consider a 1/4" diameter hole not too big? Thanks!
    That is larger than I would have used, but should still be fine/minimal evaporation.
