Thread: bridge rectifiers
    Jun 2013
    Bel Air Maryland
    21
    bridge rectifiers
    where are the bridge rectifiers located on a aqua rite swg board.I cannot seem to figure out why I keep blowing fuses immediately after installing it.No board damage,replaced fuse holder,the cell and the flow switch are not hooked up.
    30,000 gals./ In ground/Vinyl liner/Cartridge filter/A.O Smith 1 1/2 HP Pump/Pool Installed in 2008/Tf-100 test kit just ordered/Aqua-Rite SWG/well water
    Re: bridge rectifiers
    Quote Originally Posted by bucadam
    From an electronics POV electrical circuits can short if components are missing (usually you just get an open). If you do not have all the components connected there could be an incomplete, or worse, bad circuit. This could be the cause of your issue. If not, is the unit under warranty? If so STOP IMMEDIATELY and return the unit before you void the warranty. If not, then I would call Aqua Rite or check their website for your model and see if they offer an electrical schematic of your unit. If that fails, then do a general search on the Internet using a well known search engine like Bing or Google. Without a schematic or extensive knowledge of electrical components and board level repair, you are bound to make it worse. Many boards have layers that are not visible to us and are really not user serviceable. These boards are what ended most component level repair.
    ******Check this first*****
    One last note: I believe that SWG's are polarity sensitive and if that gets reversed it could cause a circuit malfunction which would trigger your fuse. Check this first!!!
    I hope this helps. Please understand this is not an exhaustive list, just my initial reaction from an electrical perspective.
    24' round AG 15K gals. DIY solar heater. SolarChlor Max producing free chlorine!!. Pool is crystal clear!! Doing my best to use natural products or processes.
