Thread: Should I raise CYA?
    lee872's Avatar
    Central Massachusetts
    59
    Should I raise CYA?
    I uncovered my pool 8 days ago. Water has been clear for 4 days and pool is clean with no signs of algae. I am still not passing OCLT though. CYA needs to come up, but I am leery of adding stabilizer for fear it gets too high. I added 2 tabs of trichlor in a floater 1 week ago and another 2 tabs yesterday. I"ve been shocking to the CYA 30 level, because I can't add chlorine during the day -- FC hasn't gone below 7 since I started.Should I bite the bullet and add stabilizer? I'm eager to stop the shock process, will CYA of 30 make a difference?
    This morning before shock:
    FC 9
    CC .5 (this has been consistent since opening)
    PH 7.5
    TA 120
    CH 220
    CYA 20
    35,000 gallons - inground vinyl liner -- sand filter - 1 HP, 50.76 GPM - Aqua Rite T-Cell 15 SWG - Dolphin Apollo Plus - TF-100
    30,421
    Re: Should I raise CYA?
    Not really. Do you know that your CYA is really 20?
    If you are not passing the OCLT, then you still have organics in your pool and must keep the shock level at 10 ppm (or a bit above) CONTINUALLY until all the organics are consumed by the chlorine.
    lee872's Avatar
    59
    I use TF-100, and I've tested CYA 3 times this week. It's been consistent.
    30,421
    Thanks. The TF-100 is about the only kit that will reach as low as 20 so that now makes sense to me.
    Just repeating, there is no advantage in going to 30 right now. Just keep replenishing your FC as often as you can, brush, filter, vacuum as often as you can and, especially, keep the faith.
    The chlorine will burn up the organics in time and your pool will look like it has never looked before.
