Thread: Repair Grout
    Repair Grout
    What do u recommend to repair the grout?
    35k IG Gunite, DE 60 SqFt filter, single speed pentair whisperflo WFE 28 2 hp 1.1 sf pump, 7 yr old pool with attach spa, Polaris 380 cleaner w/ booster pump, Jackson, New Jersey
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Repair Grout
    Polyurethane caulk (not silicone) should work better than anything else. It provides a more rubber-like texture and adheres well to masonry. It is also paintable and seems to remain very flexible even in direct sunlight.
