Results 1 to 14 of 14
Thread: PLEASE HELP !!!!!! Away for week found this
    Mar 2012
    Eastern Long Island,New York
    82
    Last week perfect,
    ph 7.5
    fc 3
    cc 0
    cya 60
    SWG 50%
    this week cloudy water as of yesterday afternoon
    Jandy SWG showed no flow I don't know why. No error codes, I have since reset it and recalibrated it and it seems to be working.
    However test results are as follows
    ph 7.5
    FC 0
    CC 3.5
    CYA 0
    How can it be zero? I live on long island and 2 really big rain storms and I drained a lot of water.The water level was over the the top of the skimmers.
    But still 0 - doesn't that seem strange. Just last week after testing for CYA with the tft 100 I added 4 pounds of CYA to the pool to bring it up to about 70.
    Ran pump over night and the cloudiness got better. Still a little cloudy. I did find 2 dead field mice in one of the skimmers.
    Please help me understand what happened to the CYA before I add more.
    Thanks
    Rich
    20 X 40 Vinyl IG 28K gallons, Heat Siphon Z700HP, Hayward 4820 DE, Hayward SP3400VSP, Jandy aquapure 1400, TFTest Kit, Pool School, Pool Calculator
    30,400
    Re: PLEASE HELP !!!!!! Away for week found this
    Tell us what kit you are testing with?
    Mar 2012
    82
    Yours )
    I put it in the original post.
    The tft 100
    Also I have had your kit for a year and its great. I have never had any problem with my pool. Like I said I tested last week and the CYA was adjusted to about 70.
    Today the CYA test tube looks like I put in tap water after putting in the mixture of the pool water and the R-0013 in the CYA mixing bottle. In fact I overflowed the special test tube.
    Thanks Dave you are the best.
    Mar 2012
    82
    Anyone? I am leaving again for the week and would appreciate suggestions regarding adding CYA. And I am also curious about what could have happened to the CYA. I don"t want to add to much.
    Thanks
    Casey's Avatar
    SW PA
    10,418
    In your first reading, you noted it as perfect and it's not. Your FC was way low to work with your CYA level of 60. Your FC target range is 7ppm with 5ppm being the lowest you should go. Now you have CC's this week.
    MAYBE.... and it's just a hunch you lost the CYA to a combination of 2 things. #1 would be to rain water and #2 would be to algae. The reason why I say #2 algae is because some pools, mine included have lost CYA over winter and I've read here a few times that it could be from something in the water converting it to nummy nums.
    If I'm wrong, I'll stand corrected when someone says so.
    Add more CYA and shock your pool.
    30,400
    Well, that is certainly a puzzle that I cannot answer. If you dosed enough to get to 70, then it should only have gone down by how much water you replaced since then. For it not to register on the test, you would have had to replace somewhere around 80-90% of your pool water.
    Any chance you used the incorrect reagent? (should be R-0013). Sure doesn't seem possible but that's all I can think of.
    That R-0013 reagent is totally inert and should really never expire so going from viable to bogus in one week seems impossible.
    EDIT: I just saw Casey's post. I would have to say that "nummy nums" may be the all time best descriptive adjective for bacteria That process is always over a winter season so I don't think is applicable here but I may remember "nummy nums" for the rest of my life.
    Mar 2012
    82
    First thanks for the response.
    Where did you see the FC should be 7ppm? I just looked on the recommended levels for a vinyl pool with a chlorine generator and these are the levels I see recommended.-
    vinyl with SWG
    FC 3-5
    pH 7.5-7.8
    TA 60-80
    CH 50-300
    CYA 70-80
    Once again thanks...
    Casey's Avatar
    SW PA
    10,418
    NUMMY!
    Casey's Avatar
    SW PA
    10,418
    CYA/CHLORINE Chart in Pool School.
    Mar 2012
    82
    Thanks again Dave
    I am positive it is the right reagant. I did it twice and just looked again. It is the biggest reagent bottle in my kit.
    Should I dose till 60 to replenish the CYA?
    I look forward to appreciating "nummy nums" when I get rid of them.
    Thanks
    30,400
    I see no choice but to dose CYA back to 60, as you are thinking. Where it went is inexplicable but perhaps it's better to go forward than to try to reconstruct.
    I had the same situation recently, had 12-14 inches rain and had to drain a couple inches a couple times to get skimming working. CYA should have been 40, was just added the week before, now it is undetectable, so I'm working on getting it back up now.
    Mar 2012
    82
    30 bottles of bleach later and three days but water is sparkling and fc held over night.
    CYA at 60
    Thanks for all help
    38,235
    BTW, you were right that the FC levels are lower for SWG pools (although 3ppm is the MINIMUM for your CYA of 60ppm), unlike what Casey was stating
