Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Coffee anyone?
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Coffee anyone?
    FC (i shocked yesterday w/ 2 gallons of 6% bleach, so while trying to read today, i just kept adding drop after drop of chlorine test and color didn't change so i stopped, felt like i was just wasting my reagents)
    cc (read above)
    PH 7.4
    TA 100
    CH 60-70
    CYA 50 (i just added about 3lbs of CYA yesterday, so I don't think i was supposed to even really test this for a full week)
    Filled from a well, pool was clear, but had fine dirt/silt on bottom of pool. After raising ph and shocking the pool turned this beautiful chocolate/coffee brown. I've read the http://www.troublefreepool.com/pool-...metal%20stains and paying $200+ for 5,000 gallons of water seems pricey to me. I have read lots of mentioning of something called 'floc' or 'floccing'...i was hoping to get more detail on this or what my next steps should be. I'm not even 100% sure its iron/metals that are the issue here.
    while filling the pool - http://i.imgur.com/q8i83bI.jpg
    after raising ph and shocking - http://i.imgur.com/MCngo6u.jpg http://i.imgur.com/yoy08fU.jpg
    I realize that the pool looks totally out of level but its actually only about 1"
    Intex 16'x48" Ultra Frame
    Intex 2,650-Gallon Sand Filter Pump
    Intex Krystal Clear Saltwater Filtration System
    Taylor K-2006
    22,549
    Re: Coffee anyone?
    That sure looks like metals to me. If you keep the water you'll be destined to maintain sequestrant in the pool for as long as you have it.
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Re: Coffee anyone?
    So youtube videos of using kitty litter to filter or special tablets to catch the iron in my sand filter will never work?
    http://www.amazon.com/Ask-the-Pool-Guy- ... B00AO8OB4E
    Whats my next step in using sequestrant? Is this easily purchased at wally world?
    Taylor K-2006
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Coffee anyone?
    I wouldn't count on that. Removing iron from water is not an easy thing to do without some very specific chemistry and equipment.
    Essential Links:
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Re: Coffee anyone?
    So is the sequestrant going to remove the brown color and make my water clear or is just going to prevent staining of the pool? I'm reading contradicting things and a little confused.
    Taylor K-2006
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Coffee anyone?
    Sequestrants will keep the metals from depositing as stains. They will not remove the metals from the water. You will need to add sequestrant periodically to keep the metals bound and prevent them from depositing as stains.
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Re: Coffee anyone?
    Quote Originally Posted by BoDarville
    So the pool will stay brown?
    Taylor K-2006
    Casey's Avatar
    SW PA
    10,444
    Re: Coffee anyone?
    No. It won't stay brown. Because if it did, many people here who fill their pools on wells probably wouldn't have a pool and spend all that money to swim in a brown/coffee colored water. I know I wouldn't. Unless it really was full of coffee n then I would just pimp my pool out to the working class!
    You just need to add the sequesterant and maintain it.
    30,419
    Re: Coffee anyone?
    I am going to change the direction of the thread just a bit. That looks like dirt to me. If it is, you can filter and vacuum and that will go away.
    You should have your well water (not your pool water) tested for iron content and let us know the result. If the result is .3 ppm or less, you can perhaps safely assume that you have sucked up a lot of dirt from your well water.
    Do you have a whole hose filter on your water? Does it get filled with dirt often? Do you happen to know the GPM capacity of your well?
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Re: Coffee anyone?
    Quote Originally Posted by Casey
    Could you recommend a brand of sequestrant? When I google the term I just get a bunch of info about a food additive.
    Taylor K-2006
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Re: Coffee anyone?
    There was definitely a looooot of dirty, sandy, silty stuff at the bottom...and when i filled i used three tube socks tied to my water hose. They turned muddy/brown.
    Can you recommend a way to test my water for iron? Our previous homeowner had a whole house filter/water softener installed but i disconnected it. I paid a company in durham to come out and show me how to operate it, but instead of teaching me anything he just "fixed it" and left...i literally had to beat info out of him. So instead of damaging what is probably thousands of dollars in equipment, i bypassed it all until i can find the help/info i need....speaking of which, is there a subform in here that could show me in dummy terms what kind of stuff i have?
    I tied a bolt to a string and dropped it in my well last week while filling the pool to measure depth. I'm about 20-23' feet deep...yeah, you read that right. and the water level was about half of that. I timed how long it took to fill a gallon jug at an outside faucet and measured 6 gallons per minute...yup, only took 10 seconds to fill that jug. I did install a new pressure pump last year because the old one had numerous leaks.
    Taylor K-2006
    30,419
    Re: Coffee anyone?
    Either purchase your own iron test ($55) or take a sample to a pool store and hope for meaningful results. You really need to identify whether or not you have significant iron in your water before you can go much further.
    1. Your well is a LOT deeper than 20'.
    2. The capacity of your well is unrelated to how fast it comes out of the hose. I think there is a good chance you exceeded the capacity of your well when filling.....you sucked it dry. When you do that, the resultant turbulence down at the pump brings a lot of dirt up from the bottom and, since you bypassed your filter, deposited it in your pool
    Can't help with your equipment on this forum....we discuss pools but no real experts on wells that I know of.
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Re: Coffee anyone?
    What leads you to believe my well is deeper than 20'?
    Will local pool stores charge to check water for iron? Seems cheaper to just assume i have metals in water?
    Taylor K-2006
    30,419
    Re: Coffee anyone?
    Unless you have a large diameter 24" or so opening (a cistern) most wells in the area are 200 feet or so....just guessing yours probably is, too.
    If you choose to presume you have metals, that's fine. You will then need to follow the above posts suggesting the use of sequestrants......that won't be cheaper for very long but that's your call.
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Re: Coffee anyone?
    Its a bored well. I can take the lid off and see the water....almost touch it. Old school stuff lol
    Im going to go back home and continue to vacuum until i can get up to capital pools and have them test my water.
    Ive stopped backwashing for a week because i put in cya.....can i cheat on this rule and check cya in a week or two and adjust accordingly?
    Taylor K-2006
    30,419
    Re: Coffee anyone?
    If your CYA has been in a week it is fully dissolved and you can backwash.
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Re: Coffee anyone?
    Leslie pools said i had no iron in my water.
    Its been 24 hrs since i added cya....can i cheat and backwash now?
    Taylor K-2006
    30,419
    Re: Coffee anyone?
    No, you will lose 50% or more of it.
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Re: Coffee anyone?
    You were correct....it was simply dirt. Got hone from the pool store and rhe water was clear.....the pump kicked off....everything settled to the botton and i vacuumed to filter. I did however go against your advice and backwash.....dark red clay water came out.....it was unbeleivable....wish i had pictures.
    Ill have to recheck cya next week and readjust.
    Taylor K-2006
  20. Back To Top    #20
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Re: Coffee anyone?
    Just thought I'd send a picture of what the water looks like now...
    This was 8am http://i.imgur.com/MCngo6u.jpg
    and
    This was 7pm (same day ) http://i.imgur.com/I43AMfe.jpg
    Taylor K-2006
