Thread: Polaris pressure side cleaner tail--no brush??
    Hi,
    Another question, the pressure side cleaner (? polaris 280?), that I use has the tail, with a sponge that claims to brush the pool. Does it do a good job? Can I skip brushing the pool myself if i run the polaris several hours each day?
    Thanks
    16,000 gallon, inground. Diamond bright finish. Hayward 1.5 hp superpump, quad 80 DE filter, Jandy legacy gas heater
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Polaris pressure side cleaner tail--no brush??
    The tail sponge on the Polaris will help, but occasional brushing with a pool brush will still be necessary.
    Well, thanks. I kind of thought that. What do you think is occasional? Once a week? Hopefully every 2 weeks?
    jkurl's Avatar
    Fairfield, ca
    141
    The little scrubber will probably last a season if you run your cleaner year around. I replaced mine last year and decided to get the tail pro scrubber that clips on. It moves more water and keeps the tail down. I have had it for a few days and noticed it blows the dirt out from the corners alot better.
    Pool Size: 20 x 40 Free Form Inground Plaster Pool w/ a shallow cove.
    Gallons : ~23K Jandy CL580 Cartridge Filter, Jandy e-pump 1.5HP
    Polaris 280 w/ Booster Pump, AqualinkRS PDA4 Remote, Aqua-Pure SWG
    Jandy LED Pool Lights (2), Heliocol 500 Sq. Ft solar rack system
