Results 1 to 7 of 7
Thread: Cloudy water - What to adjust first?
    Jun 2013
    Virginia
    3
    I shocked my pool a 2 weeks ago and got rid of green algae, added 6 bags of salt to get back up to @3200 and kept my SWG set at 60%. Chlorine production has been good, but water remains a bit cloudy. My filter cartridge was worn down, so I replaced it with a new cartridge 2 days ago. Water is still a bit cloudy. Below are my updated test results from yesterday:
    Free Chlorine = 5.9 ppm
    Total Chlorine = 6.2
    Combined Chlorine = 0.3
    pH = 8.0
    Hardness = 48
    Alkalinity (w/ stabilizer correction) = 59
    Cyanuric Acid = 23
    Copper = 0
    Iron = 0
    Total Dissolved Solids = Not run
    Pool info: 21,000 gallon Fiberglass / Pentair SWG / Waterway ProClean 200 Cartridge Filter / 2-speed Hayward Pump (0.5/2.0 HP)
    Since the chlorine level appears high, I turned off my SWG yesterday. I realize most of the other chemicals need balancing as well... my question is in what order should I balance these first? And which is most likely causing the slightly cloudy water?
    Normally, I would lower pH first, but if I let the chlorine level come back down a bit.. will that lower the pH on its own?
    Pool info: 21,000 gallon Fiberglass / Pentair SWG / Waterway ProClean 200 Cartridge Filter / 2-speed Hayward Pump (0.5/2.0 HP) / Polaris 360
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Cloudy water - What to adjust first?
    To my knowledge, cloudy is dead algae. Keep filtering and cleaning the filter when the pressure is too high.
    -- Guy --
    Welcome!
    If your water is not clear, you are not done with the shock process. Visit pool school and read and follow the How To Do The Shock Process article.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Also, with pH is considered reliable of FC is below 10. So bring yours down before you begin the shock process.
    How are you testing.
    Also, CYA should be higher with an swg. But for now, turn it off and manually dose with bleach until the shock process is complete and you pass the three part test set out in the article i referenced above. Then raise your Cya to maintain FC with the swg.
    Jun 2013
    Virginia
    3
    My local Ace Hardware store has pool supplies and they have a computer to test the water sample. My test strips actually make the pH appear mid-7.5 range, but I assume the computer test showing 8.0 is more correct? We had heavy rain on Friday (6 inches), so I had to drain pool a bit. Not sure if that affected pH. I ran test on Saturday (strips and computer).
    SkyKid's Avatar
    Apr 2013
    Upstate South Carolina
    137
    Hello and Welcome
    First thing you need is a real test kit like I have
    The TF-100 then when you get it read the instructions and post your numbers for the Pro's here
    Then listen to what they tell you and your pool will be Sparkling Clean in no time
    I went from a very green pool to Sparkling Clean in less than 2 weeks
    14600gal, In-Ground Fiberglass, Haywood s244t Sand Filter, Jandy Apure35 SWG,
    Haywood 2 speed 1hp pump, Haywood Pool Shark, TF-100 Test Kit http://tftestkits.net/
    Pool School http://www.troublefreepool.com/categ...etting_started
    Never been Pool Stored Thanks to TFP
