Thread: Swg vs buy chlorine
    May 2009
    Trenton NJ
    497
    Swg vs buy chlorine
    Anyone ever figure out how long it takes to get your money back on a swg vs paying for chlorine. Or do people mostly buy for convenience?
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,004
    Re: Swg vs buy chlorine
    It's been done many times. Here's some search results. Happy reading.
    It is mostly for convince.
    On the average pool bleach and a SWG break even in the very long run, though on any particular pool it could come out slightly better one way or the other. If you factor in the capital cost of buying the SWG up front instead of buying bleach over time, bleach is a better deal.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by ethany
    Most people I know that go with SWG do so for convenience. If you travel a lot and the pool is left unattended for several days at at time, a SWG is the way to go.
    Mar 2007
    San Rafael, CA USA
    12,082
    In general, the economics swing more towards the SWG when a pool that is in full sunlight is larger in volume. That's because the cost of the chlorine linearly scales up with the volume of pool water while the cost of larger SWGs scales up less than linearly and generally the electricity cost is a minor part of the overall cost -- it's mostly about the capital cost allocation (initial cost and ongoing cell replacement).
    May 2012
    NW PA, halfway between Pittsburgh and Erie in the PA snowbelt
    159
    Quote Originally Posted by BoDarville
    It certainly is convenient. I will dose my pool at 10:00 this morning and I am 700 miles away
    Even with my cheap Intex stuff, I figure I would just have to replace/maintenance stuff earlier making the cost probably the same as the better SWG systems.
    Mike
    22' round Intex UltraFrame pool, Intex 633T 2500gph paper cartridge filter/pump
    with broken Intex SWG, using bleach this year
    TF-100 test kit
