Results 1 to 7 of 7
Thread: Cheap Chlorine
    Cheap Chlorine
    I tried a search for this topic, but I appologize if this isn't the right spot or appropriate. I know I read one thread discussing chlorine costs. I thought I'd put it out there. Two times in the past several weeks I've purchased 8.25% bleach from Walmart for $0.99. That's 67% off and seems to me to be about as cheap as it comes. Any thoughts?
    4500 gallon 9'x18'x52"
    Krystal Clear Model 635 Filter | 1500 gal/hr
    Krystal Clear Saltwater System
    Links: Pool School | The Pool Calculator | CYA/Chlorine Chart
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Cheap Chlorine
    What size is the bottle?
    Re: Cheap Chlorine
    Those dirty suckers...it's 121oz. They increased the concentration and lowered the volume. I think it's still a good deal at $0.99
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Cheap Chlorine
    Yes, that is a good deal!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Cheap Chlorine
    0.99/(121*0.0825)= $0.10/oz NaClO...awesome price!
    38,370
    Re: Cheap Chlorine
    Was looking for chlorine at Wal-Mart today ... No 10% anywhere and no big jugs of 8.25% anywhere ... too many TFPers around here
    Had to go to Lowe's.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Re: Cheap Chlorine
    My local pool store sells 10.5% chlorine in 2.5 gallon carboys for $5.80. You have to buy the empty carboys for $5.80 each the first time, then refills are $5.80. That works out to be $.17/oz and that's the lowest price I've seen around here.
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
