Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: DIY 18x33 oval agp project
    timothy918's Avatar
    May 2013
    Hebron, Indiana
    11
    This is my 18x33 oval agp project I'm working on. I dug 60% with a skid loader and dug out the other 40% by hand. I'm doing the final leveling now. This is slow a going process the ground is mostly clay.
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Re: DIY 18x33 oval agp project
    Looking good!!
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    HamburgerChef's Avatar
    Apr 2013
    Indianapolis Indiana
    100
    Was it too hard to get level with the skid loader. Is that why you had to shovel so much?
    13,500gal AGP Matrix 24'
    Pentair Sanddollar SD-80 75GPM filter, Pentair Dynamo 1HP 2 speed pump
    Polaris 65 pool cleaner
    (20'x30" solar heater to be installed)
    timothy918's Avatar
    May 2013
    Hebron, Indiana
    11
    Quote Originally Posted by HamburgerChef
    I thought I had it level with the skid loader. But once I put the level down on the ground I was at least 5" off on the side closer to the house. I've been a shoveling fool. I dug the first 12" by hand then I hit clay. I'm in the process of the final leveling now. I used my water level and set all the patio stones for the uprights now I'm working off of the patio stones. I should be done leveling tomorrow.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by timothy918
    My back aches with empathy for you.
    But you're doing it right. An extra day or two making sure it's level-level-level will save you ten times that much work if it's not.
    timothy918's Avatar
    May 2013
    Hebron, Indiana
    11
    Quote Originally Posted by Richard320
    That's what I keep trying to explain to my wife and daughter. It has to be level.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    I feel for you brother, but your doing it right and that will pay dividends...trust in that!!!
    I've seen several threads here over the years where oval owners had to tear down and re-level, and no matter how much work that first leveling is, it will never be as much work as draining, disassembling and doing it over again.
    Keep on going
    30,408
    Adding three words of encouragement. Level. Level. Level.
    Keep pluggin'.
    Casey's Avatar
    SW PA
    10,427
    Leveling is the hardest and most crucial part!!!
    timothy918's Avatar
    May 2013
    Hebron, Indiana
    11
    Thanks for all the encouragement. I learned that leveling is the most important thing here and at poolforum.
    timothy918's Avatar
    May 2013
    Hebron, Indiana
    11
    Update Re: DIY 18x33 oval agp project
    I finished leveling the ground yesterday and what do you know it stormed last night and now I have 4" of standing water. I'm draining it now. My plan was to get the foam bottom prepped and put down so I could get the wall put up today. All that is out the window. Now I'll have to wait a few days for the ground to dry up a bit.
    Richard320's Avatar
    Jan 2010
    18,967
    That puddle is a good way to check for low spots!
    Apr 2013
    100
    Rain got us too. About 2.5" worth came down last night. I am gonna go for it anyway. Bobcat, riding tamp, and laser transit will be here tomorow. Then 24 hours of intense site leveling and packing. Hope to be done by Monday morning with site prep. Maybe start putting up the wall by within a week.
    Casey's Avatar
    SW PA
    10,427
    I've got a mud pit myself! I can't do anything til it dries out.
    timothy918's Avatar
    May 2013
    Hebron, Indiana
    11
    Got the foam down and cut to size and got the pool wall up today. Now I just have to wait for the bottom to dry completely then I can put the foam back down and put the liner in.
    timothy918's Avatar
    May 2013
    Hebron, Indiana
    11
    Update DIY 18x33 oval agp project
    Got the liner installed today. Gonna start filling tomorrow.
    Apr 2013
    100
    Looks like we are building pools in tandem. I did the shop vac trick with the liner and now the pool is about half full with no wrinkles.
    timothy918's Avatar
    May 2013
    Hebron, Indiana
    11
    update DIY 18x33 oval agp project
    I used the shop vac to get the liner smooth also. Started filling it today, got the uprights installed. Tomorrow I'll get the top ledges installed and maybe start back filling. It's been a long hard journey but I can see the light at the end of the tunnel. My next project is a deck.
    timothy918's Avatar
    May 2013
    Hebron, Indiana
    11
    The pool is now complete. Just completed all the backfilling. My wife put down some grass seed. Next on the agenda is the deck.
    Anybody know any decent deck planning website's?
  20. Back To Top    #20
    deckplans.com has some quick simple deck designs that are made with dek-blocks vs traditional posts. I also like using the Lowes Deck designer. http://www.lowes.com/deckdesigner
    21' Round 48" Deep Doughboy Timberline III, 9100 Gallons
    Using 80lb Media Master sand filter and 1HP Powerpak II.
