Thread: Trying to get an Aqualink to speak with the AquaRite
    Hey... also having the same problem here... trying to get an Aqualink to speak with the AquaRite... had no problems on using the two until I upgraded the power control board to Firmware R. Using the same wiring configuration, I'm not able to get the aqualink to recognize the Chlorine generator. I tried working through the various emulation codes offered on another thread to AL-5 on the Aqua Rite but no luck yet. Any help would be appreciated or the name of the device that connects the two... thanks in advance... I'm new to this forum and am finding it very helpful with a variety of pool related stuff... great work!
    35k Gunite, Aquarite SWG T-Cell 15, DE Filter
    Attached Spa, Water Leveler (from well / metals)
    Polaris 380, Jandy RS8 with Aqualink
    Cape Cod, Massachusetts
    Re: Hayward interface with Jandy Aqua Link?
    forget it!! I just needed to reboot the power to the panel after switching the emulation to AL-5 and all is as it should be... FINALLY!!! THANKS AGAIN TO THIS FORUM AND POSTERS FOR THE EXCELLENT ADVICE!!!!!
    Jul 2015
    239
    Re: Trying to get an Aqualink to speak with the AquaRite
    I realize this is an old post but I am having the same issue and hope someone can help. It's an older aqualink board, firmware K.
    Wiring is color matching and I'm using AL-5 emulation. Any thoughts?
    Thanks!
    - Flappy
    16,500 gallon IG Pool & Spa: Intelliflo VS pump, Pentair Triton II TR-100 sand filter, Teledyne Laars Lite2 propane heater
    Laminar Jets (2): Hayward Maxflow SP1600 1/2HP, Hayward Star Clear C500 cartridge filter
    Jandy iAqualink RS-8 Rev T, Hayward AquaRite AQR15, Dolphin Supreme M5, Taylor K-2006, Taylor K-1766
    May 2013
    23
    Need more information: Are you still running Rev K on the Aqaulink or did you upgrade? What SWG and revision is it running?
    Jandy iAqualink RS-8 Rev T, OneTouch, Chlorinator Translator, & AquaRite Rev 1.3
    Jul 2015
    239
    Thanks for the reply. I am running Rev K on the Aqualink and the OneLink unit confirms this in the diagnostics screen. SWG is a Hayward Goldline AquaRite AQR15. Here are troubleshooting steps taken thus far:
    1. Validated cross connect with an ohm meter. Assuming 1-4 pinout should be the same, the wiring is good.
    2. Tried each emulation mode, AL0 - AL5 with powerdown after each change.
    AquaRite "remotely controlled" LED is lit but I only see the active filter pump and (previously installed) temperature probes on the OneTouch. The AquaRite unit works fine from its own control box when remote control wiring is removed.
    Edit: AquaRite revision is 1.59
    I appreciate any help you can provide.
    Thanks!
    - Flappy
    Jul 2015
    239
    Update: The error was all mine. I had expected to see the AquaRite show up on the OneTouch status screen automagically and didn't realize it needed to be turned on in system setup first. The hours wasted - Oy vey.
    Everything is now working like a champ with AquaRite emulation set to AL-0.
    - Flappy
