Results 1 to 7 of 7
Thread: Liquidator not keeping up
    Aug 2009
    Keene, Texas
    157
    I installed a liquidator and am using 10% liquid chlorine in it. I have the valve wide open on it and the ball only goes up to maybe 2 or three and the chlorine level will come all the way down to about .5 if I don't have chlorine to the pool. I have looked at pics of others installations and it seems to be installed right. not sure what I can do. The pool is a 24 ft above ground and I have a brand new 1.5 HP Hi Flow Waterway pump. Any suggestions on what I should look for?
    amoses (Aaron)
    Converted from Baquaqoo in the fall of 09. Best thing I ever did!!
    AG, 24 Ft Round, 54" wall, 48" deep, 13,500 gal., TF-100 test kit
    Hi-Flo II 1.5 HP pump, AquaTools High Rate 200# Sand Filter AT3120
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Liquidator not keeping up
    AG pools often struggle with the Liquidator because they have little head. You can restrict return flow a little or consider doing the 3/8" upgrade to the Liquidator to improve flow.
    Aug 2009
    Keene, Texas
    157
    I already have the 3/8 upgrade installed. Restricting the return line will help? any suggestion on the best way to do that and how much? Thanks for the help!
    amoses (Aaron)
    22,539
    I gave my sister my LQ and we have to keep the suction valve partially closed on her pool in order to get enough suction for the LQ to have enough flow to keep the FC up. She has a very short suction line.
    Aug 2009
    Keene, Texas
    157
    I don't have a valve in my suction, just the one in the line before the gauge with the ball in it. Am I suppose to have a valve (there is a check valve) in the suction side? Maybe I will need to install one in there. Maybe I should have kept the original smaller valves and used that on the suction side instead of the 3/8 upgrade stuff?
    Thanks for the suggestions.
    amoses (Aaron)
    22,539
    I'm talking about the line from the skimmer to the pump when I said suction. You have to restrict the flow through that line before the LQ hookup.
    Aug 2009
    Keene, Texas
    157
    I see. Thanks for the clarification. I don't have a valve there. However, I may be able to rig up something else to restrict it somewhat. Thanks for the suggestion.
    amoses (Aaron)
