Results 1 to 7 of 7
Thread: Pool smells sweet and is cloudy
    Well I have an interesting question. I will admit, I havent been a good pool owner this season. I opened the pool (10,000 fiberglass) about 3 weeks ago. Work and other life has really prevented me from staying on top of testing and chemicals, but I digress.
    I use the BBB method and shocked up to 12 when I opened and vacuumed. There was a funny smell this year though. It is a sweet smell, almost like fermenting fruit, or fruit that has ripened too long, but not rotten. It doesn't smell like a pond or scummy. My wife says it has a slight yeast smell. I'm having a hard time describing it. I have shocked several times, but the smells remains. It's eating though chlorine like it means business. I finally have time this weekend to do a proper shock and keep an eye on it to keep the levels high until it stops dropping overnight. Anyway, any ideas on what is growing in there? Also, it is cloudy, but is starting to clear a little over the past day.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Pool smells sweet and is cloudy
    It's probably just the organics giving it that smell. It's seems you are aware of the proper shock method followed here. Post a full set of test results and we'll dive in. No pun intended.
    Quote Originally Posted by sypher.mp3
    Like you said...probably not the proper way.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    I assumed it was from some organic. Anyway, here are my numbers as of this morning. I added shock last night, but didnt get a chance to test after adding. According to poolcalculator, it should have shocked up to 12.
    This morning.
    FC: 8 (theoretical overnight drop from 12 to 8, but I am not going to rely on this until I do a real overnight drop test)
    CC: 0
    pH: 7.5
    TA: 120
    CH: 140 (maybe a little low? its fiberglass)
    CYA: Didnt check. It was low 3 days ago, <20. I added 2 lbs of dichlor, which should have bumped it by ~12? Im waiting a week before testing it again, but I'll ballpark it around 20-30.
    It's still a little cloudy, but seems to be going in the right direction. The sweet smell is still there, but fainter. I'm running the pump 24/7. I may wash out the cartridge this morning. Anything else I should be doing? I feel like its close to being good to get in, but the odd smell makes me cautious. The sweet smell overpowers the faint chlorine smell. Thanks!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Wild stab here, but was the pool winterized? And if so, is there any chance some genius used automotive antifreeze in the lines? Ethylene glycol antifreeze smells and tastes sweet. It is toxic, however, so just take my word for the taste.
    It was winterized. I used RV antifreeze that said specifically on the bottle for pools. That does have me wondering though. I will have to find some and see if it smells like that. Any problems swimming in it?
    Just found an extra bottle of the antifreeze. It does have a sweet smell. That may be it. But it does say non-staining and non-toxic.
    Richard320's Avatar
    Jan 2010
    19,052
    That's probably propylene glycol. They use it in foods, too. I'm not sure for what.
