Thread: Can I swapp the lines?
    Can I swap the inlet and return lines as I psted before water is about an inch off so it barley covers skimmer with kids splashing I have to keep adding water, yesterday alone we rane hose twice. Will it hurt anything if the inlet is low and return is higher?
    14X42 Intex Ultra Frame
    It isn't a good idea to swap the lines. The return doesn't have a basket, as the skimmer does, to strain out the larger debris. So it is fairly easy for the return to get clogged. If the return got clogged by a person it could be very painful.
    Is there any reason you can't just raise the water level?
    I can't really raise the water level as the ground is about an inch uneven, it's an intex pool we don't use the pump when the kids are in it. The inlet is almost at the top of the pool, almost to the top rail.
    Jun 2008
    Raleigh, NC
    Re: Can I swapp the lines?
    This one got lost in the move...
    It sounds as if your lines are already reversed... the inlet line (from pool to pump) should be the lower of the two.
    The outlet is closest to the top.
    Intex 15'x48", BBB since day three!
    Hot Spring Portable Spa, one of the originals! 350 gallons. Closed for the summer.
    880 gallon Koi pond.
    Irrigation system for 1 acre.
    1 very busy water well!
    Water quality is always important.
    When we put the pool back up I got the lines right now the inlet is lower in the water the water is staying nice and clear.
