Thread: Algae or not?
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Algae or not?
    My pool is clear, FC has been above 3 with cya at 35, no signs of anything green on walls or fittings... but, there's weird gold stuff on my cleaner hose. It's like gold paint was dripped along it. "Puddles" about .2" x .5", randomly on the hose, mostly near the cleaner (deeper). I rubbed it off a couple days ago, now there's more. Mustard algae?
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Algae or not?
    Run the overnight loss test and also measure CC. That should tell you if it's organic.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Re: Algae or not?
    Nothing growing.
    8:30PM: FC = 4.0, CC = .5
    6:30AM: FC = 4.5, CC = 0
    Seems odd, pump not running, both taken from same spot 18" deep. Anyway, looks more like pollen. Real strange, was back this morning after having wiped the hose yesterday.
    DIY chlorine feed
    BBB
    30,411
    Re: Algae or not?
    Frog eggs.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Re: Algae or not?
    I thought that might be a possibility. Did have a frog in the skimmer a couple weeks ago, haven't seen it since. I'll clean the hose OUT of the pool today!
    DIY chlorine feed
    BBB
