Thread: Just keep swimming from WV....
    Hi all. Been awhile since I have joined a forum. I've lurked for about a week after discovering a disheartening issue and now see that before we jumped in, pun intended, should have joined this forum 6 years ago. Learning lots. Take care.
    24 above ground
    Aqua-Trol SWG
    1/2 horsepower Hayward sand filter pump
    Not sure about some of the other poolese you all use yet!
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,113
    Re: Just keep swimming from WV....
    Welcome! Just across the river in Ohio here. If ya got any questions ask away.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    rowdy1:
    Welcome to TFP !
    A couple of things to help us help you...
    • 1. Please add to your profile the state and nearest city in which you live. Your climate is important to the advice you receive. By doing this, it will appear in all your posts without you having to enter it each time.
      2. Suggest adding information about your pool and related equipment in your signature. By doing this, it will automatically appear in all your posts so you do not have to re-enter it each time. If you have a SWG, please include those letters in your signature so it stands out as the advice for SWG vs. non-SWG is often different.
    Here's how to do both of the above: Adding location to your profile and pool info to your signature.
    If you don't already have one, you will need a good test kit to properly manage your pool. Here is a comparison of the recommended Test Kits
