Thread: Can a Cartridge Filter Vacuum to Waste?
    Not sure if this is the best board to post on, or the algae board since my need to vacuum to waste likely comes from a problem I was having with algae....that said,
    I was told that cartridge filters can't vacuum to waste, but I don't know if that's true. Coming off of my pump is a spigot that allows water to freely drain when I need it to, such as when my water level is too high. I also have a valve before the filter that can be turned to prevent the water from going into the filter.
    Does this setup sound like I could vacuum to waste, and if so, since I have a 2 speed filter, is it safe to use the high setting or just the low setting?
    Thanks in advance.
    18,000 gallons IG plaster pool
    cartridge filter
    2 speed pump
    22,548
    Re: Can a Cartridge Filter Vacuum to Waste?
    A spigot is very small and will restrict the water flow a lot. You can do it that way but it's really gonna affect the suction of the vacuum. You can take the cartridge out of the filter and open the drain and vacuum that way.
    Mar 2011
    Grand Rapids, Michigan
    279
    i have vac'd to waste by pulling the cart out pulling my return hose off.
    17,500 gal. ABG Doughboy Pool
    1/2 HP Pump/150 sq.ft. Cartridge Filter
    TF100 Test Kit And Speedstir
    Great. Thanks for the suggestions!
    cartridge filter
    2 speed pump
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Yes it can, mostly. I've installed a valve on the 1.5 inch plug on the bottom of my cartridge filter. Works well when I need to drain it down, but have never needed to vac to waste. It's always been clear. Thanks to the info found on this site.
    Here's how I did it: adding-a-to-waste-drain-to-plumbing-solved-t35088.html?hilit=drain%20valve
    Knoxville, TN
    41
    Or you can install a 3 way valve after the pump and before the filter. When you want to vacuum to waste turn the valve so it diverts the water away from the filter. I would draw something, but I'm no artist.
    Hot Springs certified service tech A
    APSP CST Certified
    CPO Certified
