Results 1 to 10 of 10
Thread: Intex Sand Filter Backwash / Drain Connection
    Jul 2009
    S. California
    157
    After doing a lot of searching here on the site I was still unable to find a simple solution to hooking up a standard backwash hose to my Intex sand filter.
    No offense to anyone who has offered some of the solutions, but they we just not to my liking.
    That said, I discovered that Intex sells a # 10849 adaptor for only $3.59 that will allow you to make a super clean FACTORY connection to the drain port of your Intex sand filter.
    It looks like this:
    [attachment=0:64ay1it5]image.jpg[/attachment:64ay1it5]
    A standard 1.5" roll-up backwash hose will then attach perfectly with a hose clamp. I then had my hose cut to the exact length needed to reach a nearby garden drain.
    The result is a backwash hose that seems like it came right from Intex with a factory screw on connector.
    Try it, you'll like it !
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    Re: Intex Sand Filter Backwash / Drain Connection
    I just ordered that part a few days ago. Still waiting on it to come in. I'm hoping it will work.
    24x54 Saltwater 8000 (thepoolfactory), Hayward 23" Sand Filter, 1.5Hp 1-Speed Power-Flo Matrix Pump, AQ-TROL SWG, AquaBot Pura 4X
    My local pool place had another adapter that fits several hose types, including a standard vacuum hose. It was about the same price as yours.
    Quote Originally Posted by BlueCorn
    Do you have a part number for that adapter, or a name for it?
    AG Intex - 4,600 gal - Cartridge Filter - 1,000 GPH pump
    Jul 2009
    S. California
    157
    While that adapter does indeed thread onto the port, it does not swivel apart from the hose. When you use it do you need to put on a clamp each time, or spin the entire hose to thread it on?
    The Intex adapter still looks to be a better solution.
    7100 gallons
    TF-100 test kit
    Sorry, I don't have the part number. I bought it at the local Leslie Pool supply but it doesn't seem to be on their website.
    I use my vacuum hose when I backflush. No clamp, just a pressure fit.
    Jul 2009
    S. California
    157
    Cool. If a pressure fit works then that sounds pretty good too
    7100 gallons
    TF-100 test kit
    Quote Originally Posted by Livinright
    Is the female fitting on that adapter 1.5" or 2"?
    Jul 2009
    S. California
    157
    I'm not certain of the size but can tell you its a non-standard Intex thread. Thus the challenge.
    7100 gallons
    TF-100 test kit
    Apr 2014
    United States
    1
    Thanks for the information, it is exactly what I am looking for !
