Results 1 to 8 of 8
Thread: First post
    First post
    Hey guys this is my first post.
    After years of pool neglect on my part and bad pool advise from the "pool store" I decided to take things in my own hands and tame the beast. I did a complete drain and refill because I wanted to start out fresh and didn't want a chemical cocktail anymore.
    I then stumbled upon this forum and read Pool School, bought a Taylor test kit, stopped going to the pool store and I have been rewarded with a crystal clear pool the last couple of months! THANKS to everyone on this site!
    The question I have is I feel like I am using too much MA. I need to add 16oz every 2 -3 days to maintain a PH below 7.8
    Is this the norm, I understand everyones pool is a little different. I have no extra aeration like water falls fountains etc.
    Here are my stats:
    PH 7.8
    FC 2.0
    TC 0.0
    ALK 100
    CH 200 (a little low?)
    CYA 30-40
    22,000 IG Plaster, 2.5 HP Pentair pump,Cartridge Filter 420 sq.ft 1HP booster pump with Zodiak Mars pool sweep(junk),Laars Heater (currently not working)
    Taylor K2006 test kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: First post
    Welcome to tfp, poolcheapskate
    What is the ph and TA of your makeup water?
    Do you have an autofill?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: First post
    That's about the same as I use, and my pool is a lot smaller than yours.
    Test your fill water.
    Re: First post
    no I do not have a auto fill.
    These are my makeup water test results:
    PH way over 8.0, even tested with 50mg with 5 drops and still over 8.0
    TA 80
    So I assume that I am not using too much MA, thanks guys
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: First post
    Are you having to add a lot of makup water?
    Re: First post
    Hard to estimate water makeup. I don't have a pool cover yet so I add approximately 3-4 inches a week.
    I only add makeup once a week so my tests are in between adding water.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: First post
    Depending on where you live, that is a lot of make up water....is it possible you have a leak?
    Re: First post
    Yea I suppose it could be possible I have a leak, have the pool about 7 years and I haven't noticed an increase in water loss, just thought evaporation. I live in Concord CA where its really hot in the summer averaging 90 deg and of course warm and sometimes hot spring months. My pool cover just arrived so hopefully that will cut down evaporation. Thanks for all the input.
